Changes between Version 13 and Version 14 of Release/2.1/Notes
Nov 18, 2009, 11:00:20 AM (14 years ago)
jng
updated notes
  • Release/2.1/Notes
    v13 v14
    3939 * King.Oracle provider requires Oracle Instant Client
    4040
    41 This normally happens if you installed MapGuide on a different machine from where the RDBMS is installed. To fix this, copy the required libraries into the MapGuide Server's FDO directory and restart your MapGuide Server.
     41This normally happens if you installed MapGuide on a different machine from where the RDBMS is installed.
     42
     43By default, these providers are not marked for installation. You may mark them for installation when going through the installer steps. However the above notes apply.
     44
     45If you do install any RDBMS FDO providers, you may need to copy any required libraries into the MapGuide Server's FDO directory and restart your MapGuide Server.
    4246
    4347== API changes ==
