Changes between Version 1 and Version 2 of Release/1.2/Notes
Apr 5, 2007, 11:42:25 PM (17 years ago)
tomfukushima
  • Release/1.2/Notes
    v1 v2
    33 * Release wiki: [wiki:Release/1.2]
    4  * Milestone: [milestone:1.2%20Release 1.2 Release]
     4 * Milestone: [milestone:1.2 1.2]
    55 * [query:?status=closed&group=component&resolution=fixed&milestone=1.2+Release&order=status Resolved Tickets]
    66
    77== Compatibility ==
    8 This release is fully compatible with resources created using the previous MapGuide Open Source releases. If you uninstall the previous release and then install this one in the same location your existing Resource Database will be preserved.
     8This release is fully compatible with resources created using the previous !MapGuide Open Source releases. If you uninstall the previous release and then install this one in the same location your existing Resource Database will be preserved.
    1010This release is compatible with [http://fdo.osgeo.org/downloads.html FDO 3.2.2].
    1212== Known Issues ==
    1313
    14 === ticket:38 ===
    15 In previous releases the GetSiteVersion call used to work for all access levels. The beta does not allow this. One consequence of this is that you must use an account with Administrator privileges to log in from Autodesk MapGuide Studio.
     14=== ticket:38 !GetSiteVersion cannot be called with Author role ===
     15In previous releases the !GetSiteVersion call used to work for all access levels. The beta does not allow this. One consequence of this is that you must use an account with Administrator privileges to log in from Autodesk !MapGuide Studio.
    1616
    1717== Submissions ==
