36 | | /// Selects features from a feature source according to the |
37 | | /// criteria set in the MgFeatureQueryOptions argument The |
38 | | /// criteria are applied to all of the features in the feature |
39 | | /// source. Use the coordinateSystem argument to set the target |
40 | | /// coordinate system if you want to transform and use fetchSize |
41 | | /// argument to set the fetch size of query. |
| 37 | /// For queries that return a large number of objects |
| 38 | /// some feature sources support improving performance by setting |
| 39 | /// fetch size in order to reduce the number of database server |
| 40 | /// round trips required to satisfy the selection criteria. |
| 41 | /// Providers that do not use a fetch size will ignore the fetch |
| 42 | /// size parameter. This does not affect the actual results of |
| 43 | /// queries as it is a performance tuning parameter. |
43 | | /// \param resource (MgResourceIdentifier) |
44 | | /// A resource identifier for the feature source. |
45 | | /// \param className (String/string) |
46 | | /// The name of the feature class from which |
47 | | /// the properties of interest are selected. |
48 | | /// \param options (MgFeatureQueryOptions) |
49 | | /// MgFeatureQueryOptions instance |
50 | | /// containing all required filters for this |
51 | | /// select operation. |
52 | | /// \param coordinateSystem (String/string) |
53 | | /// The name of the coordinate system to transform to. |
| 45 | /// <!-- Syntax in .Net, Java, and PHP --> |
| 46 | /// \htmlinclude DotNetSyntaxTop.html |
| 47 | /// void SetFetchSize(int fetchSize); |
| 48 | /// \htmlinclude SyntaxBottom.html |
| 49 | /// \htmlinclude JavaSyntaxTop.html |
| 50 | /// void SetFetchSize(int fetchSize); |
| 51 | /// \htmlinclude SyntaxBottom.html |
| 52 | /// \htmlinclude PHPSyntaxTop.html |
| 53 | /// void SetFetchSize(int fetchSize); |
| 54 | /// \htmlinclude SyntaxBottom.html |
| 55 | /// |
62 | | virtual MgFeatureReader* SelectFeatures( |
63 | | MgResourceIdentifier* resource, |
64 | | CREFSTRING className, |
65 | | MgFeatureQueryOptions* options, |
66 | | CREFSTRING coordinateSystem, |
67 | | INT32 fetchSize ) = 0; |
68 | | |
69 | | /// \brief |
70 | | /// Selects groups of features from a feature source and applies |
71 | | /// filters to each of the groups according to the criteria set |
72 | | /// in the MgFeatureAggregateOptions argument. Use fetchSize |
73 | | /// argument to set the fetch size of query. |
74 | | /// |
75 | | /// \param resource (MgResourceIdentifier) |
76 | | /// A resource identifier for the feature |
77 | | /// source. |
78 | | /// \param className (String/string) |
79 | | /// The name of the feature class on which |
80 | | /// the select operation is performed. |
81 | | /// \param options (MgFeatureAggregateOptions) |
82 | | /// An MgFeatureAggregateOptions instance |
83 | | /// containing all the criteria and filters |
84 | | /// required for this select operation. |
85 | | /// \param fetchSize (int) |
86 | | /// The fetch size of query. This method returns all data |
87 | | /// of query if setting the fetch size to 0. |
88 | | /// |
89 | | /// \return |
90 | | /// Returns an MgDataReader containing the group values. |
91 | | /// |
92 | | virtual MgDataReader* SelectAggregate( |
93 | | MgResourceIdentifier* resource, |
94 | | CREFSTRING className, |
95 | | MgFeatureAggregateOptions* options, |
96 | | INT32 fetchSize) = 0; |
| 63 | void SetFetchSize(INT32 fetchSize); |
