Changes between Version 4 and Version 5 of MapGuideRfc82
Aug 25, 2009, 11:21:37 PM (15 years ago)
klain
  • MapGuideRfc82
    v4 v5
    5656    /// <!-- Syntax in .Net, Java, and PHP -->
    5757    /// \htmlinclude DotNetSyntaxTop.html
    58     /// virtual bool IsNull(string propertyName);
    59     /// \htmlinclude SyntaxBottom.html
    60     /// \htmlinclude JavaSyntaxTop.html
    61     /// virtual boolean IsNull(String propertyName);
    62     /// \htmlinclude SyntaxBottom.html
    63     /// \htmlinclude PHPSyntaxTop.html
    64     /// virtual bool IsNull(string propertyName);
     58    /// virtual bool IsNull(int index);
     61    /// virtual boolean IsNull(int index);
     64    /// virtual bool IsNull(int index);
    6565    /// \htmlinclude SyntaxBottom.html
    6666    ///
    8686    /// <!-- Syntax in .Net, Java, and PHP -->
    8787    /// \htmlinclude DotNetSyntaxTop.html
    88     /// virtual bool GetBoolean(string propertyName);
    89     /// \htmlinclude SyntaxBottom.html
    90     /// \htmlinclude JavaSyntaxTop.html
    91     /// virtual boolean GetBoolean(String propertyName);
    92     /// \htmlinclude SyntaxBottom.html
    93     /// \htmlinclude PHPSyntaxTop.html
    94     /// virtual bool GetBoolean(string propertyName);
     88    /// virtual bool GetBoolean(int index);
     91    /// virtual boolean GetBoolean(int index);
     94    /// virtual bool GetBoolean(int index);
    9595    /// \htmlinclude SyntaxBottom.html
    9696    ///
    119119    /// <!-- Syntax in .Net, Java, and PHP -->
    120120    /// \htmlinclude DotNetSyntaxTop.html
    121     /// virtual unsigned char GetByte(string propertyName);
    122     /// \htmlinclude SyntaxBottom.html
    123     /// \htmlinclude JavaSyntaxTop.html
    124     /// virtual signed char GetByte(String propertyName);
    125     /// \htmlinclude SyntaxBottom.html
    126     /// \htmlinclude PHPSyntaxTop.html
    127     /// virtual int GetByte(string propertyName);
     121    /// virtual unsigned char GetByte(int index);
     124    /// virtual signed char GetByte(int index);
     127    /// virtual int GetByte(int index);
    128128    /// \htmlinclude SyntaxBottom.html
    129129    ///
    152152    /// <!-- Syntax in .Net, Java, and PHP -->
    153153    /// \htmlinclude DotNetSyntaxTop.html
    154     /// virtual MgDateTime GetDateTime(string propertyName);
    155     /// \htmlinclude SyntaxBottom.html
    156     /// \htmlinclude JavaSyntaxTop.html
    157     /// virtual MgDateTime GetDateTime(String propertyName);
    158     /// \htmlinclude SyntaxBottom.html
    159     /// \htmlinclude PHPSyntaxTop.html
    160     /// virtual MgDateTime GetDateTime(string propertyName);
     154    /// virtual MgDateTime GetDateTime(int index);
     157    /// virtual MgDateTime GetDateTime(int index);
     160    /// virtual MgDateTime GetDateTime(int index);
    161161    /// \htmlinclude SyntaxBottom.html
    162162    ///
    185185    /// <!-- Syntax in .Net, Java, and PHP -->
    186186    /// \htmlinclude DotNetSyntaxTop.html
    187     /// virtual float GetSingle(string propertyName);
    188     /// \htmlinclude SyntaxBottom.html
    189     /// \htmlinclude JavaSyntaxTop.html
    190     /// virtual float GetSingle(String propertyName);
    191     /// \htmlinclude SyntaxBottom.html
    192     /// \htmlinclude PHPSyntaxTop.html
    193     /// virtual float GetSingle(string propertyName);
     187    /// virtual float GetSingle(int index);
     190    /// virtual float GetSingle(int index);
     193    /// virtual float GetSingle(int index);
    194194    /// \htmlinclude SyntaxBottom.html
    195195    ///
    218218    /// <!-- Syntax in .Net, Java, and PHP -->
    219219    /// \htmlinclude DotNetSyntaxTop.html
    220     /// virtual double GetDouble(string propertyName);
    221     /// \htmlinclude SyntaxBottom.html
    222     /// \htmlinclude JavaSyntaxTop.html
    223     /// virtual double GetDouble(String propertyName);
    224     /// \htmlinclude SyntaxBottom.html
    225     /// \htmlinclude PHPSyntaxTop.html
    226     /// virtual double GetDouble(string propertyName);
     220    /// virtual double GetDouble(int index);
     223    /// virtual double GetDouble(int index);
     226    /// virtual double GetDouble(int index);
    227227    /// \htmlinclude SyntaxBottom.html
    228228    ///
    251251    /// <!-- Syntax in .Net, Java, and PHP -->
    252252    /// \htmlinclude DotNetSyntaxTop.html
    253     /// virtual short GetInt16(string propertyName);
    254     /// \htmlinclude SyntaxBottom.html
    255     /// \htmlinclude JavaSyntaxTop.html
    256     /// virtual short GetInt16(String propertyName);
    257     /// \htmlinclude SyntaxBottom.html
    258     /// \htmlinclude PHPSyntaxTop.html
    259     /// virtual int GetInt16(string propertyName);
     253    /// virtual short GetInt16(int index);
     256    /// virtual short GetInt16(int index);
     259    /// virtual int GetInt16(int index);
    260260    /// \htmlinclude SyntaxBottom.html
    261261    ///
    284284    /// <!-- Syntax in .Net, Java, and PHP -->
    285285    /// \htmlinclude DotNetSyntaxTop.html
    286     /// virtual int GetInt32(string propertyName);
    287     /// \htmlinclude SyntaxBottom.html
    288     /// \htmlinclude JavaSyntaxTop.html
    289     /// virtual int GetInt32(String propertyName);
    290     /// \htmlinclude SyntaxBottom.html
    291     /// \htmlinclude PHPSyntaxTop.html
    292     /// virtual int GetInt32(string propertyName);
     286    /// virtual int GetInt32(int index);
     289    /// virtual int GetInt32(int index);
     292    /// virtual int GetInt32(int index);
    293293    /// \htmlinclude SyntaxBottom.html
    294294    ///
    317317    /// <!-- Syntax in .Net, Java, and PHP -->
    318318    /// \htmlinclude DotNetSyntaxTop.html
    319     ///  virtual long GetInt64(string propertyName);
    320     /// \htmlinclude SyntaxBottom.html
    321     /// \htmlinclude JavaSyntaxTop.html
    322     ///  virtual long GetInt64(String propertyName);
    323     /// \htmlinclude SyntaxBottom.html
    324     /// \htmlinclude PHPSyntaxTop.html
    325     ///  virtual string GetInt64(string propertyName);
     319    ///  virtual long GetInt64(int index);
     322    ///  virtual long GetInt64(int index);
     325    ///  virtual string GetInt64(int index);
    326326    /// \htmlinclude SyntaxBottom.html
    327327    ///
    352352    /// <!-- Syntax in .Net, Java, and PHP -->
    353353    /// \htmlinclude DotNetSyntaxTop.html
    354     /// virtual string GetString(string propertyName);
    355     /// \htmlinclude SyntaxBottom.html
    356     /// \htmlinclude JavaSyntaxTop.html
    357     /// virtual String GetString(String propertyName);
    358     /// \htmlinclude SyntaxBottom.html
    359     /// \htmlinclude PHPSyntaxTop.html
    360     /// virtual string GetString(string propertyName);
     354    /// virtual string GetString(int index);
     357    /// virtual String GetString(int index);
     360    /// virtual string GetString(int index);
    361361    /// \htmlinclude SyntaxBottom.html
    362362    ///
    385385    /// <!-- Syntax in .Net, Java, and PHP -->
    386386    /// \htmlinclude DotNetSyntaxTop.html
    387     /// virtual MgByteReader GetBLOB(string propertyName);
    388     /// \htmlinclude SyntaxBottom.html
    389     /// \htmlinclude JavaSyntaxTop.html
    390     /// virtual MgByteReader GetBLOB(String propertyName);
    391     /// \htmlinclude SyntaxBottom.html
    392     /// \htmlinclude PHPSyntaxTop.html
    393     /// virtual MgByteReader GetBLOB(string propertyName);
     387    /// virtual MgByteReader GetBLOB(int index);
     390    /// virtual MgByteReader GetBLOB(int index);
     393    /// virtual MgByteReader GetBLOB(int index);
    394394    /// \htmlinclude SyntaxBottom.html
    395395    ///
    418418    /// <!-- Syntax in .Net, Java, and PHP -->
    419419    /// \htmlinclude DotNetSyntaxTop.html
    420     /// virtual MgByteReader GetCLOB(string propertyName);
    421     /// \htmlinclude SyntaxBottom.html
    422     /// \htmlinclude JavaSyntaxTop.html
    423     /// virtual MgByteReader GetCLOB(String propertyName);
    424     /// \htmlinclude SyntaxBottom.html
    425     /// \htmlinclude PHPSyntaxTop.html
    426     /// virtual MgByteReader GetCLOB(string propertyName);
     420    /// virtual MgByteReader GetCLOB(int index);
     423    /// virtual MgByteReader GetCLOB(int index);
     426    /// virtual MgByteReader GetCLOB(int index);
    427427    /// \htmlinclude SyntaxBottom.html
    428428    ///
    451451    /// <!-- Syntax in .Net, Java, and PHP -->
    452452    /// \htmlinclude DotNetSyntaxTop.html
    453     /// virtual MgByteReader GetGeometry(string propertyName);
    454     /// \htmlinclude SyntaxBottom.html
    455     /// \htmlinclude JavaSyntaxTop.html
    456     /// virtual MgByteReader GetGeometry(String propertyName);
    457     /// \htmlinclude SyntaxBottom.html
    458     /// \htmlinclude PHPSyntaxTop.html
    459     /// virtual MgByteReader GetGeometry(string propertyName);
     453    /// virtual MgByteReader GetGeometry(int index);
     456    /// virtual MgByteReader GetGeometry(int index);
     459    /// virtual MgByteReader GetGeometry(int index);
    460460    /// \htmlinclude SyntaxBottom.html
    461461    ///
    484484    /// <!-- Syntax in .Net, Java, and PHP -->
    485485    /// \htmlinclude DotNetSyntaxTop.html
    486     /// virtual MgRaster GetRaster(string propertyName);
    487     /// \htmlinclude SyntaxBottom.html
    488     /// \htmlinclude JavaSyntaxTop.html
    489     /// virtual MgRaster GetRaster(String propertyName);
    490     /// \htmlinclude SyntaxBottom.html
    491     /// \htmlinclude PHPSyntaxTop.html
    492     /// virtual MgRaster GetRaster(string propertyName);
     486    /// virtual MgRaster GetRaster(int index);
     489    /// virtual MgRaster GetRaster(int index);
     492    /// virtual MgRaster GetRaster(int index);
    493493    /// \htmlinclude SyntaxBottom.html
    494494    ///
