Changes between Version 35 and Version 36 of MapGuideRfc78
Jul 24, 2009, 8:30:25 AM (15 years ago)
brucedechant
  • MapGuideRfc78
    v35 v36
    145145Timeout configuration for !MgTransaction
    146146
    147 As the transaction is a critical resource for database applications, a server-side transaction can be left open while the application is doing other things in between sql or even worse the application may fail or hang and the server would not know. So it needs to set a timeout for all transactions. If a transaction hasn't been committed or rollbacked within the timeout, the server will automatically rollback the transaction. If you call Commit() or Rollback() on the MgTransaction instance after timeout, an exception will be thrown reminding that the transaction has been timeout and reverted.
     147As the transaction is a critical resource for database applications, a server-side transaction can be left open while the application is doing other things in between sql or even worse the application may fail or hang and the server would not know. So it needs to set a timeout for all transactions. If a transaction hasn't been committed or rollbacked within the timeout, the server will automatically rollback the transaction. If you call Commit() or Rollback() on the !MgTransaction instance after timeout, an exception will be thrown reminding that the transaction has been timeout and reverted.
    148148
    149149Two items will be added into serverconfig.ini for transaction timeout setting. If the transaction hasn't been committed or rollbacked within 6 minutes, it will be automatically rollbacked.
    154154Bind !MgTransaction to FDO connection
    155155
    156 The transaction has to be bound with the underlying FDO connection where it starts during its life circle. The underlying FDO connection will be kept used by the transaction until the call of either Commit() or Rollback(). The implementation of MgTransaction should be able to return the underlying connection.
     156The transaction has to be bound with the underlying FDO connection where it starts during its life circle. The underlying FDO connection will be kept used by the transaction until the call of either Commit() or Rollback(). The implementation of !MgTransaction should be able to return the underlying connection.
    157157
    158158== Implications ==
