Changes between Version 19 and Version 20 of MapGuideRfc6
- Feb 22, 2007, 3:56:07 PM (17 years ago)
MapGuideRfc6
v19 v20 31 31 If a feature source geometry contains an incorrect coordinate system or does not have a coordinate system defined, this provides a convenient way to change the coordinate system without having to change the data of the feature source. 32 32 33 !MapGuide can only deal with spatial data with a specified coordinate system. Changing the behaviour to allow the specification of a coordinate system override allows you to use data that you may not otherwise.33 !MapGuide can only deal with spatial data with a specified coordinate system. The behaviour to allow the specification of a coordinate system override allows you to use data that you may not otherwise. 34 34 35 35 == Proposed Solution ==
