Changes between Version 5 and Version 6 of MapGuideRfc67
- Jun 19, 2009, 9:05:57 AM (15 years ago)
MapGuideRfc67
v5 v6 31 31 === Print Layout and Print Layout Elements === 32 32 33 The detailed schema containing definitions of the print layout, print layout element, and print layout element definition can be found in the attached documents. The XSD definition of the schema can be found in the attached [http://trac.osgeo.org/mapguide/attachment/wiki/MapGuideRfc67/PrintLayout-1.1.0.xml Print Layout Definition] or in its associted detailed documentation files in [http://trac.osgeo.org/mapguide/attachment/wiki/MapGuideRfc67/PrintLayoutSchema.doc microsoft word] or [http://trac.osgeo.org/mapguide/attachment/wiki/MapGuideRfc67/PrintLayoutSchema.mht html] formats.33 The detailed schema containing the definitions of the print layout, print layout element, and print layout element definition can be found in the attached documents. The XSD schema definition can be found in the attached [http://trac.osgeo.org/mapguide/attachment/wiki/MapGuideRfc67/PrintLayout-1.1.0.xml Print Layout Definition] or in its associted documentation files in [http://trac.osgeo.org/mapguide/attachment/wiki/MapGuideRfc67/PrintLayoutSchema.doc microsoft word] or [http://trac.osgeo.org/mapguide/attachment/wiki/MapGuideRfc67/PrintLayoutSchema.mht html] formats. 34 34 35 35 The print layout element design involves defining an entry point for creating print layout and its elements. This entry point is called '''!MgPrintLayoutServiceBase'''.
