Changes between Version 24 and Version 25 of MapGuideRfc67
Jun 19, 2009, 1:35:45 PM (15 years ago)
gregboone
  • MapGuideRfc67
    v24 v25
    220220    • Client builds a layer definition, if applicable (for !MapViewport resources, this step is not necessary) that references the feature source definition and adds it to Resource Service by calling !SetResource.[[BR]]
    221221
     222==== Adding a print layout element ====
     223
     224This use case is part of use cases that realize a particular type of print layout element.
     225
     226[[BR]]
     227    [[Image(AddPrintLayoutElementUseCase2.PNG, 1400)]]
     228[[BR]]
     229
     230''PRECONDITIONS''
     231
     232    • Adding required data for map viewport creation use case
     233
     234''STEPS''
     235
     236    • Client builds an Xml for a particular type of print layout element.  In this Xml, he specifies the Data.!ResourceId property to point to the feature source definition and the Stylization.ResourceId property to point to the layer definition created in the previous steps.  He also sets the fully qualified feature class name of the print layout element data in Data.FeatureClass property.[[BR]]
     237    • Client adds this Xml to Resource Service by calling !SetResource(printLayoutElementResId, printLayoutElementXml)[[BR]]
     238    • The Resource Service implementation creates an instance of !PrintLayoutResourcesOwner if not already created and adds it to a named dictionary.[[BR]]
     239    • The Resource Service calls !AddResource on !MapPrintLayoutResourcesOwner object.[[BR]]
     240    • !PrintLayoutResourcesOwner determines the type of the print layout element that is being added and creates an runtime representation object for the resource. In case of !MapViewport resources, this would be !MapViewportResource, inherited from !MapResource class.[[BR]]
     241    • !PrintLayoutResourcesOwner then adds this runtime object to Resource Manager and also subscribes to Resource Manager events, if not already done.[[BR]]
     242
    222243
    223244== Implications ==
