Changes between Version 10 and Version 11 of MapGuideRfc49
Jun 16, 2008, 11:26:01 AM (16 years ago)
trevorwekel
  • MapGuideRfc49
    v10 v11
    9393== Implications ==
    9494
    95 Level 0 matches the existing functionality set without the trace log.  The enhanced Level 1 to 3 functionality will be implemented over time.
     95Level 0 matches the existing functionality set without the trace log.  Since code change is required, not all operations or services will support the enhanced detail.  The additional detail will be implemented on an as required basis.
    9696
    97 Additional internal C++ code constructs will be introduced within the !MapGuide Server code base to implement the enchanced functionality.  These constructs are internal only and beyond the scope of this RFC.
     97Internal C++ code constructs will be introduced within the !MapGuide Server code base to implement the enhanced functionality.  These constructs are internal only and beyond the scope of this RFC.
    9898
    9999== Test Plan ==
    100100
    101
     101 * The detail discrimination mechanism will be tested for one service.
     102 * Testing will be performed at the highest level of detail for each service to ensure information is written to the logs.
    102103
    103104== Funding/Resources ==
