Changes between Version 5 and Version 6 of MapGuideRfc25
Aug 9, 2007, 1:40:03 PM (17 years ago)
jasonchen
  • MapGuideRfc25
    v5 v6
    3939An additioanl OEM component has been added to the source -- jsoncpp. Jsoncpp is a C++ implementation of the JSON specification (http://sourceforge.net/projects/jsoncpp/).
    4040
    41 Two additional classes have been added to assist the JSON implementation in MapGuide:
    42 1) The MgJsonDoc Class
    43 - MgJsonDoc is a wrapper over the jsoncpp implementation. MgJsonDoc provides many easy-to-use interfaces, such as Begin* and End*, for creating JSON documents from an XML perspective. For example, to create as JSON document for the corresponding XML content---<Node>Text</Node>---, one would call BeginObject("Node"), SetValue("Text"), and EndObject() subsequently.
     41Two additional classes have been added to assist the JSON implementation in !MapGuide:
     421) The !MgJsonDoc Class
     43- !MgJsonDoc is a wrapper over the jsoncpp implementation. !MgJsonDoc provides many easy-to-use interfaces, such as Begin* and End*, for creating JSON documents from an XML perspective. For example, to create as JSON document for the corresponding XML content---<Node>Text</Node>---, one would call !BeginObject("Node"), !SetValue("Text"), and !EndObject() subsequently.
    4444
    45452) The MgXmlJsonConvert Class
    46 - MgXmlJsonConvert converts an XML document into a JSON formatted document.
     46- !MgXmlJsonConvert converts an XML document into a JSON formatted document.
    4747
    4848The following Web-tier to Server APIs are affected:
    5050Coordinate System
    5151
    52 # EnumerateCategories (1)
    53 # EnumerateCoordinateSystems (1)
    54
     52# !EnumerateCategories (1)
     53# !EnumerateCoordinateSystems (1)
    5554
    5655Resource
    5756
    58 # EnumerateResourceReferences (3)
    59 # EnumerateResources (3)
    60 # GetResourceContent (3)
    61 # GetResourceHeader (3)
    62 # EnumerateResourceData (3)
    63 # GetResourceData (3)
    64 # EnumerateUnmanagedData (3)
     57# !EnumerateResourceReferences (3)
     58# !EnumerateResources (3)
     59# !GetResourceContent (3)
     60# !GetResourceHeader (3)
     61# !EnumerateResourceData (3)
     62# !GetResourceData (3)
     63# !EnumerateUnmanagedData (3)
    6564
    6665Feature
    6766
    68 # GetFeatureProviders (3)
    69 # GetCapabilities (3)
    70 # GetConnectPropertyValues (1)
    71 # DescribeSchema (4)
    72 # SelectFeatures (2)
    73 # SelectAggregates (1)
    74 # GetSpatialContexts (1)
    75 # GetLongTransactions (1)
    76 # EnumerateDataStores (3)
    77 # GetSchemaMapping (3)
    78 # GetSchemas (1)
    79 # GetClasses (1)
    80 # GetClassDefinition (2)
    81 # GetIdentityProperties (1)
    82 # ExecuteSqlQuery (1)
    83 # GetFdoCacheInfo (4)
     67# !GetFeatureProviders (3)
     68# !GetCapabilities (3)
     69# !GetConnectPropertyValues (1)
     70# !DescribeSchema (4)
     71# !SelectFeatures (2)
     72# !SelectAggregates (1)
     73# !GetSpatialContexts (1)
     74# !GetLongTransactions (1)
     75# !EnumerateDataStores (3)
     76# !GetSchemaMapping (3)
     77# !GetSchemas (1)
     78# !GetClasses (1)
     79# !GetClassDefinition (2)
     80# !GetIdentityProperties (1)
     81# !ExecuteSqlQuery (1)
     82# !GetFdoCacheInfo (4)
    8483
    8584Rendering
    8685
    87 # GetVisibleMapExtent (1)
     86# !GetVisibleMapExtent (1)
    8887
    8988where the appended labeling scheme indicates the different implementation considerations:
    90 (1) Web-tier changes -- every ToXml function is matched with an ToJson function implementation that creates a JSON document in place,
    91 (2) Web-tier changes -- utilizes the MgXmlJsonConvert class to convert XML documents to JSON documents.
    92 (3) Server changes -- an extra parameter "CREFSTRING format" has been added to the respective API call; the MgXmlJsonConvert class is used if format equals to the JSON MIME type.
    93 (4) Server changes -- an extra API has been added matching the respective API call (e.g. DescribeSchemaAsXml has DescribeSchemaAsJson as its counter part, and GetFDOCacheInfo has GetFDOCacheInfoAsJson as its JSON specific implementation); this is because the original APIs return "STRING" and could not be efficiently adapted by the conversion process within the MgXmlJsonConvert class implementation; and for the affected APIs, the MgByteReader* is returned instead.
     89(1) Web-tier changes -- every !ToXml function is matched with an !ToJson function implementation that creates a JSON document in place,
     90(2) Web-tier changes -- utilizes the !MgXmlJsonConvert class to convert XML documents to JSON documents.
     91(3) Server changes -- an extra parameter "CREFSTRING format" has been added to the respective API call; the !MgXmlJsonConvert class is used if format equals to the JSON MIME type.
     92(4) Server changes -- an extra API has been added matching the respective API call (e.g. !DescribeSchemaAsXml has !DescribeSchemaAsJson as the JSON version, and !GetFDOCacheInfo has !GetFDOCacheInfoAsJson as its JSON specific implementation); this is because the original APIs return "STRING" and could not be efficiently adapted by the conversion process within the !MgXmlJsonConvert class implementation; and for the affected APIs, the !MgByteReader* is returned instead.
     93
    9494
    9595== Implications ==
