Changes between Version 17 and Version 18 of MapGuideRfc16
- Feb 26, 2007, 8:28:12 AM (17 years ago)
MapGuideRfc16
v17 v18 37 37 === Layer Definition Schema Modifications === 38 38 39 The layer definition schema contains numerous <!ExtendedData1> elements that allow the schema to be extended without breaking forward or backward compatibility. The changes proposed in this RFC would initially be added into one of these elements, and would eventually be moved to the main part of the schema whenever the next schema version update is carried out. See [ http://wiki.osgeo.org/index.php/MapGuide_RFC_10_-_Make_Schemas_More_Amenable_to_Interim_EnhancementsMapGuide RFC 10] for more details.39 The layer definition schema contains numerous <!ExtendedData1> elements that allow the schema to be extended without breaking forward or backward compatibility. The changes proposed in this RFC would initially be added into one of these elements, and would eventually be moved to the main part of the schema whenever the next schema version update is carried out. See [wiki:MapGuideRfc10 MapGuide RFC 10] for more details. 40 40 41 41 The affected section of the original schema looks like this:
