Changes between Version 12 and Version 13 of MapGuideRfc126
- May 8, 2013, 4:59:00 AM (11 years ago)
MapGuideRfc126
v12 v13 231 231 232 232 {{{ 233 <?xml version="1.0" encoding="UTF-8"?>234 233 <FeatureInformation> 235 <FeatureSet xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:noNamespaceSchemaLocation="FeatureSet-1.0.0.xsd"> <Layer id="2dbc571a-b5a1-11e2-8004-080027004461"> <Class id="SHP_Schema:Parcels"> <ID>DiQAAA==</ID> </Class> </Layer></FeatureSet><Tooltip /> 236 <Hyperlink /> 237 <InlineSelectionImage /> 238 <Attributes> 239 <BatchPropertyCollection><PropertyCollection><Property><Name>_MgLayerName</Name><Type>string</Type><Value>Parcels</Value></Property><Property><Name>_MgFeatureBoundingBox</Name><Type>string</Type><Value>-87.719208640129452 43.747730625310957 -87.71745819670727 43.748609259038986</Value></Property><Property><Name>Description1</Name><Type>string</Type><Value>ORIG. PLAT</Value></Property><Property><Name>Zone</Name><Type>string</Type><Value>EXM</Value></Property><Property><Name>Acreage</Name><Type>string</Type><Value>3.21</Value></Property><Property><Name>Lot Dimensions</Name><Type>string</Type><Value>IRREG</Value></Property><Property><Name>Owner</Name><Type>string</Type><Value>CITY OF SHEBOYGAN</Value></Property><Property><Name>Description2</Name><Type>string</Type><Value>ALL OF BLOCKS 186 & 187, AND</Value></Property><Property><Name>Description3</Name><Type>string</Type><Value>VACATED S. 11TH ST. BETWEEN</Value></Property><Property><Name>Billing Address</Name><Type>string</Type><Value>828 CENTER AVE</Value></Property><Property><Name>Lot Size (SqFt)</Name><Type>string</Type><Value>140000</Value></Property><Property><Name>Description4</Name><Type>string</Type><Value>SD BLOCKS, EXCEPT THE W 10'</Value></Property></PropertyCollection></BatchPropertyCollection></Attributes> 234 <FeatureSet xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:noNamespaceSchemaLocation="FeatureSet-1.0.0.xsd"> 235 <Layer id="a754a6f0-b7d5-11e2-8004-080027004461"> 236 <Class id="SHP_Schema:Parcels"> 237 <ID>1R8AAA==</ID> 238 </Class> 239 </Layer> 240 </FeatureSet> 241 <Tooltip></Tooltip> 242 <Hyperlink></Hyperlink> 243 <InlineSelectionImage></InlineSelectionImage> 244 <SelectedFeatures> 245 <SelectedLayer id="a754a6f0-b7d5-11e2-8004-080027004461" name="Parcels"> 246 <LayerMetadata> 247 <Property> 248 <Name>RLDESCR1</Name> 249 <Type>9</Type> 250 <DisplayName>Description1</DisplayName> 251 </Property> 252 <Property> 253 <Name>RTYPE</Name> 254 <Type>9</Type> 255 <DisplayName>Zone</DisplayName> 256 </Property> 257 <Property> 258 <Name>RACRE</Name> 259 <Type>9</Type> 260 <DisplayName>Acreage</DisplayName> 261 </Property> 262 <Property> 263 <Name>RLOT</Name> 264 <Type>9</Type> 265 <DisplayName>Lot Dimensions</DisplayName> 266 </Property> 267 <Property> 268 <Name>RNAME</Name> 269 <Type>9</Type> 270 <DisplayName>Owner</DisplayName> 271 </Property> 272 <Property> 273 <Name>RLDESCR2</Name> 274 <Type>9</Type> 275 <DisplayName>Description2</DisplayName> 276 </Property> 277 <Property> 278 <Name>RLDESCR3</Name> 279 <Type>9</Type> 280 <DisplayName>Description3</DisplayName> 281 </Property> 282 <Property> 283 <Name>RBILAD</Name> 284 <Type>9</Type> 285 <DisplayName>Billing Address</DisplayName> 286 </Property> 287 <Property> 288 <Name>RSQFT</Name> 289 <Type>7</Type> 290 <DisplayName>Lot Size (SqFt)</DisplayName> 291 </Property> 292 <Property> 293 <Name>RLDESCR4</Name> 294 <Type>9</Type> 295 <DisplayName>Description4</DisplayName> 296 </Property> 297 </LayerMetadata> 298 <Feature> 299 <Bounds>-87.722788142888234 43.755335868606466 -87.721634440510442 43.756252668096828</Bounds> 300 <Property> 301 <Name>Description1</Name> 302 <Value>ORIGINAL PLAT</Value> 303 </Property> 304 <Property> 305 <Name>Zone</Name> 306 <Value>MER</Value> 307 </Property> 308 <Property> 309 <Name>Acreage</Name> 310 <Value>1.61</Value> 311 </Property> 312 <Property> 313 <Name>Lot Dimensions</Name> 314 <Value>IRREG</Value> 315 </Property> 316 <Property> 317 <Name>Owner</Name> 318 <Value>MRED (14TH/ERIE) ASS</Value> 319 </Property> 320 <Property> 321 <Name>Description2</Name> 322 <Value>CSM REC IN VOL 17 P 242-4 AS</Value> 323 </Property> 324 <Property> 325 <Name>Description3</Name> 326 <Value>DOC #1593757 ROD BEING PRT</Value> 327 </Property> 328 <Property> 329 <Name>Billing Address</Name> 330 <Value>W228 N745 WESTMOUND</Value> 331 </Property> 332 <Property> 333 <Name>Lot Size (SqFt)</Name> 334 <Value>70140</Value> 335 </Property> 336 <Property> 337 <Name>Description4</Name> 338 <Value>OF LOTS 2 & 6 AND ALL OF</Value> 339 </Property> 340 </Feature> 341 </SelectedLayer> 342 </SelectedFeatures> 240 343 </FeatureInformation> 241 344 }}} … … 244 347 245 348 {{{ 246 <?xml version="1.0" encoding="UTF-8"?>247 349 <FeatureInformation> 248 <FeatureSet xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:noNamespaceSchemaLocation="FeatureSet-1.0.0.xsd"> <Layer id="2dbc571a-b5a1-11e2-8004-080027004461"> <Class id="SHP_Schema:Parcels"> <ID>DiQAAA==</ID> </Class> </Layer></FeatureSet><Tooltip /> 249 <Hyperlink /> 350 <FeatureSet xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:noNamespaceSchemaLocation="FeatureSet-1.0.0.xsd"> 351 <Layer id="e3ec8e66-b7d5-11e2-8004-080027004461"> 352 <Class id="SHP_Schema:Parcels"> 353 <ID>2x4AAA==</ID> 354 </Class> 355 </Layer> 356 </FeatureSet> 357 <Tooltip></Tooltip> 358 <Hyperlink></Hyperlink> 250 359 <InlineSelectionImage> 251 <MimeType> 252 image/png</MimeType> 253 <Content> 254 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</Content> 360 <MimeType>image/png</MimeType> 361 <Content>iVBORw0KGgoAAAANSUhEUgAAAtsAAALTCAYAAADHI87FAAAABHNCSVQICAgIfAhkiAAAEJtJREFUeJzt3c+OI1cVB+BT3aNJT0I0CmJAChIrskBIwJINS54AgQQ7NrwGylOwZ4PEA7Bjh4RYspggsUiQgICEICghYcjMdLGwrdTctt12d3nqntPfJ1n+0+XynVF3+Xevj09FAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAADAHTIsPQCgio++GHHx7YjhIiLGiHFcXce43mCMiMst92Oy3SGXWO/7yH2Nm20v4+q4xohxz/PHfePY8tzNa42XzWuPEZeXLz5/HCMu1/efX65ub+5/ehnxdHN7jHgyRry7fq3HY8Tb038HAB0StoEZ/OthxMNfRMTnlx7JHXXABOXK5OTQyc5cz73tvq57nW0TsH0Try0TroP/TUe81sHPPfC1x8uIeBbx7PcRD/4UQPfuLT0AoILPfTNWQfsiIl7dssG+1ddtPzt2+5s8Ptdrz/W6xz7+sv6PCsq8zrQZ+/2nEU9+EnHxh0WHA1xL2AZmMLyyvvFKRLyx5EiY3RITkptMJJZ67SX287+I+Dji3nciQtiGzgnbwBzO1tebZbe/RsQ/msemt9ulxeu22bb9Ifs4ZH83fd4x47jpa1cZR/vczEvLPfgoIj4O7+GQgj9UYA5nzf0PYhW44Tq7JgnHhP5DtrnJxGGJcezb/vWI+Ork/mUA3RO2gTm0YRsO1ZZJ3LH68aN8IVZhe/rlSqBz3iCBObQrdEIAzK9dAX++yCiAowjbwBzaY4mwDafn7wwSELaBOTiWwOm1nxyp2YYEvEECc2i7kVhxg9PzdwYJCNvAHNpaUiEA5te+Z6vZhgSEbWAGg2MJvDy6kUAi3iCBOSgjgdNrP0FSsw0JCNvAHHQjgZdP2IYEhG1gDk6/DaenGwkkJGwDc7CyDafni8iQkLANzKGt2QZObtSNBBIQtoE5tMcSH2/D/NoyEivbkICwDczBijacnm4kkJCwDcxB6z94+fydQQLCNjAHxxI4vXZlW802JOANEpiDbiRwemq2ISFhG5jD0FwLAXB6arYhgXtLDwAooZ24vxkRD5vHxi23tz126Da7Vvf2bfNJRPwnICcntYGEhG1gDm3Y/soiozjMOxHx3tKDgBvQjQQSEraBOTxZX380ub2xqy3gtsf3tRA8Zj+7Hn8Yq4mAsE0FyrUgAWEbmMHTX0fc/+H6zn8XHcp+DyPifOlBwA1Z2YaEhG1gBg/ei/jgexGvfS1Wx5UhYpj23t51iViVoEzvD/Fi3+4tl6Hddrhm+x9HxMV6G6uBZNXUbI/CNiQgbAMzeePfEfHbpUex3fMfRcSD9R1hm6ysbENCWv8Bd4HTyVORiSMkIGwDd8H0WCegkFXb+s8ZJCEBYRu4C4RtKvK7DAkI28BdMP0SpYBCVmq2ISFhG7gL1GxTgTNIQkLCNnAXTHtrW9kmq2bSqPUfZCBsA3fBtI83VGHiCAkI28Bd4AuSVKBmGxIStoHq2lVtYZvs1GxDIsI2UNwvp6d+h8ysbENCwjZQ3KM2oFjZJqumG8nodxkSELaB4h61xzkBhSqcQRISELaB4u5vVgOVkZCdT2kgIWEbKO618+YBAYWs9NmGhIRtoLgzq4FUoxsJJCJsA8Xd042EKnQjgYSEbaC4c1+QpIq2jMTvMiQgbAPFnQnbVNG0/rOyDRkI20B1upFQlC9IQgbCNlCclW3K0I0EEhK2geIGYZtqxuYa6JiwDRQnbFNGs7J96QySkICwDVSnZpsq9IyHhIRtoDgr25TRdCO5VLMNCQjbQHFXwjZUYeIICXgTAqprzyApoJBVU0byTM02JCBsA8UN6lypwhkkISFhG6jufOkBwMzWIfuZmm1IQNgGqmu7kVgNJKtmZfupsA0JCNtAcbqRUNUTYRsSELaB6oRtqmg+nfnU7zIkIGwD1bXdSCCr5nf4Hd1IIAFhGyhONxKqeux3GRIQtoHqHOeooikjeVvYhgS8CQHVOakNVUw/pRnD7zKkIGwD1fmCJFVMw7Z6bUhC2Aaq88VIqrGqDYkI20BxQ3sGSSGFrKYTRz22IQlhG6jOGSSpSNiGJIRtoDo121QxnTAK25CEsA1U5zhHFW03EiABb0JAdVr/UYVuJJCQsA1UpxsJFZk0QhLCNlCdmm2qULMNCQnbQHGDMhKqULMNCQnbQHVWtqnIyjYkIWwD1anZpoohPpssCtuQxL2lBwBwYr2fQfJ+RHwjIh7G1bGNzfWu27ued8w+DtnfyxjHrp8fM75exnGb19n28+kCmbANSQjbQHW9n0HyrYj4UqzGZRWe61jZhmSEbaC63svlXl1f/yUiPt2xzb4Qvutnxzx+6v3P+dqnHs+xrzvXax+67SZsP9uzPdARYRuorveV7XZc/2weHw68bLY92/Lc3iccHG383dIjAA4jbAPVJetG8vfvR3z5kxPtfIj46RDx9SHi0RDx+hBxMUTcX4fzi7OI8/Xts2F1OT/77P6wvkRzO2LVYvGF+5OQP0wmBcOWScJwFlcnDbu23/f86XPPru7ryn4j9k9OrpvcbBn3cIvnbh3Llsv454jf/CqAFIRtoLre66Cb8T0/5WRgjHi788kGQC0+WgSq670bSRO2n/jiG0AhwjZQXVuz3av1JOBDYRugEGEbqK73mu1mEvCusA1QiLANFDdkCdvrcf1A2AYoRNgGqpt2h4joL2y3eh8fAEcQtoHqeq/Vno7PqjZAMcI2UF2WMpIIYRugHGEbqK4tI+nVGMI2QDnCNlBde5zrLdBa2QYoTNgGqut9RXs6vt5KXAC4JWEbqG5zBsneu5EoIwEoSNgGqsu0si1sAxQjbAPV6UYCwGKEbaC6LCe1GaPfsQFwQ8I2UF3vxzkr2wCF9f4mBHBbbc12b6vHwjZAYcI2UN15c7+3sD0lbAMUI2wD1Q3NdW+G+GwCIGwDFCNsA9Vl6kbS29gAuCVhG6iuXdnuLdCq2QYoTNgGqmtrtnukjASgKGEbqE43EgAWI2wD1fVesz0lbAMUI2wD1bVnkOzNtBtJzxMBAG5A2Aaq631lWxkJQGHCNlBd7zXbU8I2QDHCNlDcsOlG0nPrP91IAIoStoHqeq3V3nBSG4DChG2gOjXbACxG2Aaqy3CcU0YCUFSGNyGA22hb//W0st2WuAjbAMUI20B1upEAsBhhG6guw8q2k9oAFCVsA9X1fJxTRgJQXM9vQgBz6L0byZSwDVCMsA1U13OfbSvbAMUJ20B1PZ9Bsh2TsA1QjLANVNdzN5KexwbADO4tPQCAE2sXFTYr3dNgu+v2y2ZlG6AYYRuorm39990jnrutJV8bxscdjx2yD2UkAMUJ20B1m0D7NK6G4l1fntz3pcr2Z0PsLsnbtp99+xa2AYoRtoHixj9GDN+KiL8tPZLrje8vPQIA5iVsA8W9/7OIN59GDG/FalV5eolYrUpvbm8eP2vuX3eJyfNusq+IiMcRH/58ln8yAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAANwx/weNt3ZF5c4jFwAAAABJRU5ErkJggg==</Content> 255 362 </InlineSelectionImage> 256 <Attributes> 257 <BatchPropertyCollection><PropertyCollection><Property><Name>_MgLayerName</Name><Type>string</Type><Value>Parcels</Value></Property><Property><Name>_MgFeatureBoundingBox</Name><Type>string</Type><Value>-87.719208640129452 43.747730625310957 -87.71745819670727 43.748609259038986</Value></Property><Property><Name>Description1</Name><Type>string</Type><Value>ORIG. PLAT</Value></Property><Property><Name>Zone</Name><Type>string</Type><Value>EXM</Value></Property><Property><Name>Acreage</Name><Type>string</Type><Value>3.21</Value></Property><Property><Name>Lot Dimensions</Name><Type>string</Type><Value>IRREG</Value></Property><Property><Name>Owner</Name><Type>string</Type><Value>CITY OF SHEBOYGAN</Value></Property><Property><Name>Description2</Name><Type>string</Type><Value>ALL OF BLOCKS 186 & 187, AND</Value></Property><Property><Name>Description3</Name><Type>string</Type><Value>VACATED S. 11TH ST. BETWEEN</Value></Property><Property><Name>Billing Address</Name><Type>string</Type><Value>828 CENTER AVE</Value></Property><Property><Name>Lot Size (SqFt)</Name><Type>string</Type><Value>140000</Value></Property><Property><Name>Description4</Name><Type>string</Type><Value>SD BLOCKS, EXCEPT THE W 10'</Value></Property></PropertyCollection></BatchPropertyCollection></Attributes> 363 <SelectedFeatures> 364 <SelectedLayer id="e3ec8e66-b7d5-11e2-8004-080027004461" name="Parcels"> 365 <LayerMetadata> 366 <Property> 367 <Name>RLDESCR1</Name> 368 <Type>9</Type> 369 <DisplayName>Description1</DisplayName> 370 </Property> 371 <Property> 372 <Name>RTYPE</Name> 373 <Type>9</Type> 374 <DisplayName>Zone</DisplayName> 375 </Property> 376 <Property> 377 <Name>RACRE</Name> 378 <Type>9</Type> 379 <DisplayName>Acreage</DisplayName> 380 </Property> 381 <Property> 382 <Name>RLOT</Name> 383 <Type>9</Type> 384 <DisplayName>Lot Dimensions</DisplayName> 385 </Property> 386 <Property> 387 <Name>RNAME</Name> 388 <Type>9</Type> 389 <DisplayName>Owner</DisplayName> 390 </Property> 391 <Property> 392 <Name>RLDESCR2</Name> 393 <Type>9</Type> 394 <DisplayName>Description2</DisplayName> 395 </Property> 396 <Property> 397 <Name>RLDESCR3</Name> 398 <Type>9</Type> 399 <DisplayName>Description3</DisplayName> 400 </Property> 401 <Property> 402 <Name>RBILAD</Name> 403 <Type>9</Type> 404 <DisplayName>Billing Address</DisplayName> 405 </Property> 406 <Property> 407 <Name>RSQFT</Name> 408 <Type>7</Type> 409 <DisplayName>Lot Size (SqFt)</DisplayName> 410 </Property> 411 <Property> 412 <Name>RLDESCR4</Name> 413 <Type>9</Type> 414 <DisplayName>Description4</DisplayName> 415 </Property> 416 </LayerMetadata> 417 <Feature> 418 <Bounds>-87.722795366494324 43.756662887792743 -87.721545117334017 43.757359091595923</Bounds> 419 <Property> 420 <Name>Description1</Name> 421 <Value>ORIGINAL PLAT</Value> 422 </Property> 423 <Property> 424 <Name>Zone</Name> 425 <Value>EXM</Value> 426 </Property> 427 <Property> 428 <Name>Acreage</Name> 429 <Value>1.12</Value> 430 </Property> 431 <Property> 432 <Name>Lot Dimensions</Name> 433 <Value>IRREG</Value> 434 </Property> 435 <Property> 436 <Name>Owner</Name> 437 <Value>REHABILITATION CENTE</Value> 438 </Property> 439 <Property> 440 <Name>Description2</Name> 441 <Value>THE W 1/2 OF LOT 1, ALL OF</Value> 442 </Property> 443 <Property> 444 <Name>Description3</Name> 445 <Value>LOTS 2, 3, 4 & 5; THE N</Value> 446 </Property> 447 <Property> 448 <Name>Billing Address</Name> 449 <Value>P O BOX 685</Value> 450 </Property> 451 <Property> 452 <Name>Lot Size (SqFt)</Name> 453 <Value>48870</Value> 454 </Property> 455 <Property> 456 <Name>Description4</Name> 457 <Value>50.00' OF LOT 6, ALSO THE N</Value> 458 </Property> 459 </Feature> 460 </SelectedLayer> 461 </SelectedFeatures> 258 462 </FeatureInformation> 259 463 }}} … … 280 484 281 485 {{{ 282 <?xml version="1.0" encoding="UTF-8"?>283 486 <FeatureInformation> 284 487 <FeatureSet /> 285 <Tooltip>Parcel\nName: WHITE, RICHARD\nAddress: 1627 INDIANA AVE</Tooltip>488 <Tooltip>Parcel\nName: TOBOTIPE, INC\nAddress: 4902 N. 18TH ST.</Tooltip> 286 489 <Hyperlink /> 287 490 <InlineSelectionImage /> … … 366 569 367 570 '''Discussion required: Currently, the following parts of the Fusion selection structure are not set by this new QUERYMAPFEATURES operation:''' 368 * '''propertynames (v2.6.0 QUERYMAPFEATURES will return the mapped property name and not the FDO property name if mapped)''' 369 * '''metadata (what widgets/functionality use this information?)''' 370 * '''metadatanames (what widgets/functionality use this information?)''' 571 * '''metadata (what widgets/functionality use this information? Current implementation blanks all values)''' 371 572 '''Should v2.6.0 QUERYMAPFEATURE also accomodate for such information?''' 372 573
