Changes between Version 2 and Version 3 of MapGuideRfc120
Jul 30, 2011, 1:07:16 AM (13 years ago)
hubu
  • MapGuideRfc120
    v2 v3
    2727== Motivation ==
    2828
    29 Currently in MapGuide, the client sends "!QueryMapFeatures" request to get  the tooltips of features under the mouse as it hovers over the map. However, most of the requests  are unnecessary and useless for the end-user. For example, when the user are doing measure/pan/zoom, the tooltips are redundant for the user. If we remove these unnecessary requests, we can reduce !MapGuide Server's overload. The new command "!MapTip" provides an opportunity for the user to disable the map tooltips, to reduce the "!QueryMapFeatures" requests. And the user still can enable the tooltips again with this command.
     29Currently in !MapGuide, the client sends "!QueryMapFeatures" request to get  the tooltips of features under the mouse as it hovers over the map. However, most of the requests  are unnecessary and useless for the end-user. For example, when the user are doing measure/pan/zoom, the tooltips are redundant for the user. If we remove these unnecessary requests, we can reduce !MapGuide Server's overload. The new command "!MapTip" provides an opportunity for the user to disable the map tooltips, to reduce the "!QueryMapFeatures" requests. And the user still can enable the tooltips again with this command.
    3030
    3131
