Changes between Version 22 and Version 23 of MapGuideRfc119
- Jul 19, 2011, 7:45:55 PM (13 years ago)
MapGuideRfc119
v22 v23 42 42 Concat('map.google.com/fid=', FeatId) 43 43 }}} 44 where '!FeatId' property is the property to identify a unique feature of the feature class. So the URL of a feature in this layer should be in the form 'map.google.com/fid=[ FeatId]' where [FeatId] part will be replaced with the actual '!FeatId' property value for each feature. However if user wants to change the URL of a specific feature(and only this one) which turns to be 'map.bing.com/fid=[FeatId]' for some reason. It is obvious that we can not change URL element value that will affect all other features. So what we can do is to specify a property of the feature class that the layer is based on where we can store this overriden value.44 where '!FeatId' property is the property to identify a unique feature of the feature class. So the URL of a feature in this layer should be in the form 'map.google.com/fid=[!FeatId]' where [!FeatId] part will be replaced with the actual '!FeatId' property value for each feature. However if user wants to change the URL of a specific feature(and only this one) which turns to be 'map.bing.com/fid=[!FeatId]' for some reason. It is obvious that we can not change URL element value that will affect all other features. So what we can do is to specify a property of the feature class that the layer is based on where we can store this overriden value. 45 45 46 46 == Proposed Solution ==
