Changes between Version 13 and Version 14 of MapGuideRfc108
Aug 12, 2010, 2:01:46 AM (14 years ago)
sparkliu
  • MapGuideRfc108
    v13 v14
    3333
    34341.      Create a new resource type for watermark, which defines content (in the format of an inline symbol definition), appearance (rotation / transparency) and position information of watermark. The schema of watermark definition is attached below.
     35        Referencing another symbol definition resource as content is not supported. There are three main reasons for this: 1) Usually, content of watermark is usually very simple (maybe just text / image). 2) The biggest reason of referencing symbol definition as a outer resource is for reusing. However, the concept of watermark already supports reuse. 3) Supports both inline and referencing outer resource is a complex idea and bring confusion to the end user (like "Which part of watermark is defined in the referenced symbol definition and which is defined in watermark definition itself?"). Using inline symbol definition will treat the watermark definition as a whole concept to the end user.
    3536
    36372.      User can add a watermark to MapDefinition or LayerDefinition by referencing corresponding watermark resource(s) in it. However, we do NOT support inline watermark in MapDefinition and LayerDefinition.
     38        The inline-and/or-reference problem also shows here. Not supporting both mode is to reduce the complexity of watermark concept. As we need to support watermark as a separate resource so that user can reuse it very easily, inline watermark is not supported.
    3739
    38403.      When MapDefinition or LayerDefinition references a watermark resource, it can choose to override its appearance and position information to bring flexibility to the user. The override attributes defining in MapDefinition or LayerDefinition has a higher priority than that in watermark when rendering.
     41        Sometimes users may want to move watermark a little (or change opacity) when using it in map / layer but don't want to change watermark in other maps referencing it. This often happens when user have two watermarks on the same map and there are some overlapping between these two watermarks. At that time, user can use this "override" mechanism to only change watermark a little in this map / layer.
    3942
    40434.      When being rendered, the watermark group of an MgMap is actually the collection of the watermarks referenced in its MapDefinition and the watermarks referenced in the LayerDefinition in it.
    4144
    42455.      When using watermark in LayerDefinition, user can decide in what situation the watermark is visible during rendering by defining “Usage” properties. For example, a watermark of a WMS layer is only visible when the value of its “Usage” properties is “WMS” or “ALL”. (There is no such problem when using watermark in MapDefinition, because it will never be used in WMS.)
     46        Currently, the value of "Usage" can be "WMS" (WMS only), "Viewer" (AJAX /Fusion Viewer only) and "ALL".
    4347
    4448
