Changes between Version 2 and Version 3 of MapGuideRfc106
- Jul 25, 2010, 7:25:13 PM (14 years ago)
MapGuideRfc106
v2 v3 32 32 It's described in WFS 1.1.0 specification section 8.1 that the only mandatory output in response to a !DescribeFeatureType request is a GML3 application schema defined using XML Schema. Because GML2 application schema is kept for backward compatibility, it is necessary for MapGuide to enhance the !HttpWfsGetFeatureType to handle different GML formats. 33 33 [[BR]][[BR]] 34 35 '''2) Enhance the !GetFeature operation to support mutiple GML formats'''[[BR]]36 [[BR]]37 In WFS 1.1.0 specification section 9.2: ''The optional output format attribute specifies the format of the response to a !GetFeature request. The default value is text/xml;subtype=gml/3.1.1 indicating that a vald GML3 document, that validate s against a valid GML3 application schema, must be generated. For backward compatibility, the value GML2 may be specified indicating that a valid GML2 document, that validates against a valid GML2 application schema, must be generated.'' So,it is necessary for MapGuide to enhance the !HttpWfsGetFeature to handle different GML formats.38 39 40 == Implications ==41 34 42 35 A new !DescribeWfsFeature API should be added to handle the output GML format … … 77 70 78 71 }}} 72 73 '''2) Enhance the !GetFeature operation to support mutiple GML formats'''[[BR]] 74 [[BR]] 75 In WFS 1.1.0 specification section 9.2: ''The optional output format attribute specifies the format of the response to a !GetFeature request. The default value is text/xml;subtype=gml/3.1.1 indicating that a vald GML3 document, that validate s against a valid GML3 application schema, must be generated. For backward compatibility, the value GML2 may be specified indicating that a valid GML2 document, that validates against a valid GML2 application schema, must be generated.'' So,it is necessary for MapGuide to enhance the !HttpWfsGetFeature to handle different GML formats. 76 [[BR]][[BR]] 79 77 80 78 A new !DescribeWfsFeature API should be added to handle the output GML format … … 125 123 126 124 125 126 == Implications == 127 127 128 == Test Plan == 128 129
