Changes between Version 4 and Version 5 of Maestro3UI
Jul 7, 2010 6:38:46 PM (8 years ago)
jng
  • Maestro3UI
    v4 v5
    4747And each new version incrementally builds on previous versions. The editor UIs as a result can follow the same pattern.
    4848
    49 As already mentioned Maestro 3.0 will not silently upgrade your edited resources. What it does however is check if a given resource is upgradeable to a new er version. If this is the case, the editor UI will display a firefox-style notification indicating that the currently edited resource can be upgraded to a newer version. If the user chooses to upgrade, the existing resource is saved, upgraded and opened in a editor that supports the given resource version.
     49As already mentioned Maestro 3.0 will not silently upgrade your edited resources. What it does however is check if a given resource is upgradeable to a newer version. If this is the case, the editor UI will display a firefox-style notification indicating that the currently edited resource can be upgraded to a newer version. If the user chooses to upgrade, the existing resource is saved, upgraded and opened in a editor that supports the given resource version.
    5050
    51 For versions that are not recognised by Maestro's resource editors (or resource types not recognised by Maestro), the XML editor is used as a fallback.
     51For versions that are not recognised by Maestro's resource editors (or resource types not recognised by Maestro), the XML editor is used as a fallback. The XML editor also has this upgrade checking capability
