Changes between Version 6 and Version 7 of MGOS2onVistaIIS7
- Oct 31, 2008, 2:24:24 PM (15 years ago)
MGOS2onVistaIIS7
v6 v7 47 47 * NOTE: Any other applications you create (e.g., Sheboygan sample) will also need to be converted to an application. 48 48 49 50 51 52 49 One final thing. It seems that you may get a system error dialog that periodically shows up. I think that this has something to do with the App Pool default idle time out. To get around this, try creating a !MapGuide App Pool and give it a timeout of 0 minutes (i.e., no timeout). Then for all the applications that you create for MapGuide, set the application pool to be the !MapGuide one. (BTW, the Application Pools node is just below the root level node with your machine name.)
