Changes between Version 9 and Version 10 of MGOS22GdalProvider
Jun 16, 2011, 2:43:59 AM (13 years ago)
jng
  • MGOS22GdalProvider
    v9 v10
    1010== Installation ==
    1111
    12 If you want to avoid problems with invalid spatial extents when setting up new layers, you may want to use the GDAL provider that Jackie compiled from and attached to #740 (please note that this is only the 32-bit provider, for 64-bit you have to compile the provider from source) :  http://trac.osgeo.org/mapguide/attachment/ticket/740/GDALProvider_493.zip
     12If you want to avoid problems with invalid spatial extents when setting up new layers, you may want to use the GDAL provider that Jackie compiled from and attached to #740:
     13
     14 * http://trac.osgeo.org/mapguide/attachment/ticket/740/GDALProvider_493.zip (32-bit)
     15 * http://trac.osgeo.org/mapguide/attachment/ticket/740/GRFPProvider_FDO35_MGOS22_x64.zip (64-bit)
    1316
    1417Tamas Szekeres is maintaining binary distributions of the GDAL library with the plugins for the !MapServer project.  His distributions work with !MapGuide.  The distributions are available here http://vbkto.dyndns.org/sdk/.  For !MapGuide 2.2, the following builds are required:
