124 | | !QueryMapFeatures for !MapGuide 2.1 is nearly identical to [#QueryMapFeatures1.2 QueryMapFeatures for MapGuide 1.2]. The only addition to the API was the addition of "ENVELOPEINTERSECTS" for the SELECTIONVARIANT parameter. |
| 124 | !QueryMapFeatures for !MapGuide 2.1 is nearly identical to [#QueryMapFeatures1.2 QueryMapFeatures for MapGuide 1.2]. The only changes to the API were the addition of "ENVELOPEINTERSECTS" for the SELECTIONVARIANT parameter and the CLIENTAGENT parameter. |
| 125 | === Parameters === |
| 126 | || '''Name''' || '''Value''' || '''Required''' || '''Description''' || |
| 127 | || [#Operation1.0 OPERATION] || GETMAPIMAGE || Yes || Operation to execute || |
| 128 | || [#Version1.0 VERSION] || 1.0.0 || Yes || Operation version || |
| 129 | || [#ClientAgent2.1 CLIENTAGENT] || text || Optional || Descriptive text for client || |
| 130 | || [#Session1.0 SESSION] || session identifier || Yes || !MapGuide session identifier containing map to display. || |
| 131 | || [#MapName1.0 MAPNAME] || text || Yes ||Name of the map to display.[[BR]]This corresponds to the !GetName() value for the resource identifier. || |
| 132 | || [#LayerNames1.0 LAYERNAMES] || text || Optional || Comma separated list of layer names. || |
| 133 | || [#MaxFeatures1.0 MAXFEATURES] || integer || Yes || Maximum number of features to select. || |
| 134 | || [#Geometry1.0 GEOMETRY] || text || Yes || WKT string representing the selection geometry. || |
| 135 | || [#SelectionVariant1.0 SELECTIONVARIANT] || text || Yes || Geometric operation to use while selecting. || |
| 136 | || [#Persist1.0 PERSIST] || 0/1 || Yes || If true, selection is saved to map. || |
| 137 | || [#LayerAttributeFilter1.0 LAYERATTRIBUTEFILTER] || integer || Optional || Filter based on layer attributes. || |
| 138 | || [#FeatureFilter1.0 FEATUREFILTER] || text || Optional || Filter based on previous selected features. || |
215 | | |
| 229 | === Parameters === |
| 230 | || '''Name''' || '''Value''' || '''Required''' || '''Description''' || |
| 231 | || [#Operation1.0 OPERATION] || GETMAPIMAGE || Yes || Operation to execute || |
| 232 | || [#Version1.0 VERSION] || 1.0.0 || Yes || Operation version || |
| 233 | || [#Session1.0 SESSION] || session identifier || Yes || !MapGuide session identifier containing map to display. || |
| 234 | || [#MapName1.0 MAPNAME] || text || Yes ||Name of the map to display.[[BR]]This corresponds to the !GetName() value for the resource identifier. || |
| 235 | || [#LayerNames1.0 LAYERNAMES] || text || Optional || Comma separated list of layer names. || |
| 236 | || [#MaxFeatures1.0 MAXFEATURES] || integer || Yes || Maximum number of features to select. || |
| 237 | || [#Geometry1.0 GEOMETRY] || text || Yes || WKT string representing the selection geometry. || |
| 238 | || [#SelectionVariant1.0 SELECTIONVARIANT] || text || Yes || Geometric operation to use while selecting. || |
| 239 | || [#Persist1.0 PERSIST] || 0/1 || Yes || If true, selection is saved to map. || |
| 240 | || [#LayerAttributeFilter1.0 LAYERATTRIBUTEFILTER] || integer || Optional || Filter based on layer attributes. || |
| 241 | || [#FeatureFilter1.0 FEATUREFILTER] || text || Optional || Filter based on previous selected features. || |
