Changes between Version 2 and Version 3 of Future/TileServiceEnhancements
Jun 26, 2013, 2:29:07 AM (11 years ago)
jng
  • Future/TileServiceEnhancements
    v2 v3
    4040ResourceHeader.
    4141
     42== API additions to MgTileService ==
     43
     44To support HTTP cacheability we need to be able to do the following via the MgTileService:
     45
     46 a) Get timestamp information about a generated tile (to be able to apply expiry dates)
     47
     48 b) "Peek" at the timestamp for a tile that may or may not be generated (to be able to compare against dates from if-modified-since headers)
     49
     50An API addition to MgTileService like the one below should be able to support the above scenarios.
     51
     52{{{
     53
     54class MG_MAPGUIDE_API MgTileService : MgService
     55{
     56PUBLISHED_API:
     57   /// Returns the timestamp of when the tile for the specified map/group/row/col was generated. Returns NULL if no such tile exists
     58   ///
     59   MgDateTime* GetTileCreationDate(MgMap* map, CREFSTRING baseMapLayerGroupName, INT32 tileColumn, INT32 tileRow);
     60
     61   /// Returns the timestamp of when the tile for the specified map/group/row/col/scale was generated. Returns NULL if no such tile exists
     62   ///
     63   MgDateTime* GetTileCreationDate(MgResourceIdentifier* mapDefinition, CREFSTRING baseMapLayerGroupName, INT32 tileColumn, INT32 tileRow, INT32 scaleIndex);
     64
     65   /// Returns the specified base map tile for the given map.  If a cached tile
     66   /// image exists it will return it, otherwise the tile is rendered and added
     67   /// to the cache.
     68   MgTile* GetTile(MgMap* map, CREFSTRING baseMapLayerGroupName, INT32 tileColumn, INT32 tileRow);
     69
     70   /// Returns the specified base map tile for the given map.  If a cached tile
     71   /// image exists it will return it, otherwise the tile is rendered and added
     72   /// to the cache.
     73   ///
     74   MgTile* GetTile(MgResourceIdentifier* mapDefinition, CREFSTRING baseMapLayerGroupName, INT32 tileColumn, INT32 tileRow, INT32 scaleIndex);
     75};
     76}}}
     78MgTile is defined like so.
     79
     80{{{
     81class MG_MAPGUIDE_API MgTile : public MgSerializable
     82{
     83PUBLISHED_API:
     84    /// Returns the tile image
     85    ///
     86    MgByteReader* GetImage();
     87
     88    /// Returns the date this tile was created
     89    ///
     90    MgDateTime* GetCreationDate();
     91};
     92
     93}}}
     94
     95== MapAgent modifications ==
     96
     97TBD
     98
    4299= WMS =
    43100
    56113
    57114
    58
    59
