Changes between Version 34 and Version 35 of ConfigureGuide22Windows
Show
09/01/10 15:46:20 (3 years ago)
hluo
  • ConfigureGuide22Windows
    v34 v35
    9090 1. Install IIS 7.x to Windows 7 or Windows 2008 Server
    9191
    92 By default, IIS 7 under Windows 7 and Windows 2008 Server is a windows feature not turned on. Under Windows 7, to turn on this feature, go to Control Panel->Programs->Turn Windows Features On or Off, in the poped up Windows Features, expand Internet Information Services, check WWW Services, click OK to install the selected features. Under Windows 2008 Server, go to Control Panel->Administrative Tools->Server Manager, in the left panel of popped up window, select Role, in the right panel, click Add Roles->Server Roles->Web Server(IIS), click OK to add the selected Role, then in the left panel, select Feature, in the right panel, click Add Features, a window with available windows features should open. Find Web Server (IIS) Tools and check it, click OK to install this feature.
     92By default, IIS 7 is not turned on under either Windows 7 or Windows 2008 Server.
     93
     94To turn on this feature under windows 7, go to Control Panel->Programs->Turn Windows Features On or Off, in the poped up Windows Features, expand Internet Information Services, check WWW Services, click OK to install the selected features.
     95
     96Under Windows 2008 Server, go to Control Panel->Administrative Tools->Server Manager, in the left panel, select Role, in the right panel, click Add Roles->Server Roles->Web Server(IIS), click OK to add the selected Role, then in the left panel, select Feature, in the right panel, click Add Features, a window with available windows features should open. Find Web Server (IIS) Tools and check it, click OK to install this feature.
    9397
    9498 2. Create registry key '''!IniFilePath'''.
    146150}}}
    147151
     152'''Note:''' Some binary PHP installer may not have '''php5isapi.dll''', you can always find a compatible one for your PHP from the internet. Here[http://www.anindya.com/php-5-3-3-x64-64-bit-for-windows/ Here] is a place to get this file for PHP 5.3.x-x64
     153
    148154== JBoss ==
    149155
