Changes between Version 21 and Version 22 of ConfigureGuide22Windows
- Aug 16, 2010, 1:17:52 PM (14 years ago)
v21 v22 46 46 * visit [http://tud.at/programm/apache-ssl-win32-howto.php3 this site] for common apache errors 47 47 * ''HTTP 403: you don't permission to /mapguide/mapadmin/login.php'' or ''anything site under /mapguide/<blabla>'' : this error means your access setting in apache config file is wrong. 48 * Login to !mapguide admin site error: '''Fatal error: Call to undefined function MgInitializeWebTier() in C:\mapguideopensource-2.2-beta1\Web\www\mapadmin\login.php on line 70''', this might be caused by the interference of existing php.ini. under windows command line, type '''regedit''' to bring up the registry window, find PHP entry and find out where the php installation is, copy php.ini toWeb/Php/ and edit its contents accordingly48 * Login to mapguide admin site error: '''Fatal error: Call to undefined function !MgInitializeWebTier() in C:\mapguideopensource-2.2-beta1\Web\www\mapadmin\login.php on line 70''', this might be caused by the interference of existing php.ini. under windows command line, type '''regedit''' to bring up the registry window, find PHP entry and find out where the php installation is, copy php.ini to !Web/Php/ and edit its contents accordingly 49 49 * browser opens to the source code of php file instead of a web page: this error means Apache is not configured correctly to use PHP. 50 50
