Changes between Version 14 and Version 15 of ConfigureGuide22Windows
- Aug 4, 2010, 10:00:34 PM (14 years ago)
v14 v15 1 1 = Configure Web Servers to run MapGuide Web Applications on Windows = 2 2 3 this document is written with windows 7as the testing platform, the process may be slightly different under windows xp. Web applications are refered in mapguide project as web extensions, but they are really the same things.3 this document is written with 64-bit windows 7 machine as the testing platform, the process may be slightly different under windows xp. Web applications are refered in mapguide project as web extensions, but they are really the same things. 4 4 5 5 Under windows, you have the options to deploy mapguide web application to either Apache, or Tomcat, or IIS 6 7 Basic knowledge of 32bit vs 64bit machine: 32bit applications works on 64bit machine, not vice versa. 32bit application does not get along with 64bit application if they have to work together. So when downloading Apache or other applications, bear in mind they have to be compatible with either hardware or software. Confused? then ignore what I say :) 6 8 7 9 == Apache2 ==
