Changes between Initial Version and Version 1 of CodeSamples/Tiles/TileCacheSeeding
Jul 18, 2008, 8:30:15 PM (16 years ago)
zspitzer
  • CodeSamples/Tiles/TileCacheSeeding
     1[[PageOutline]]
     3This page is one of the !MapGuide Community CodeSamples.  Visit the CodeSamples page to view more!
     5== Seeding the Mapguide Tile Cache for a Tiled Map ==
     7The attached script uses OpenLayers to display a tiled map and provides the functionality to pan[[BR]]
     8and scan across the entire map, optionally for all scale levels.
     10The logic is quite simple. Starting for the center of the map, it will pan left, then up and down to[[BR]]
     11calculate the number of rows and then right to calculate the number of columns. This could be simply[[BR]]
     12calculated but the tiles need to be requested anyway.
     13
     14Once that is known, the script will then either starting panning left to right down one and then [[BR]]
     15right to left and so on to request (and thus seed) the entire map.
     16
     17There is also an option to use a randomised request pattern.
     18
     19The attached file is configured to work with the sheboygan sample.
     20
     21== Future ==
     23The randomised logic could be improved generate the random list once rather than the approach currently used.
     25Making the script into a fusion widget
     27Some of a code cleanup :)
     28
     29
     30
