Changes between Version 3 and Version 4 of CodeSamples/Fusion/SuperSimple
- Dec 18, 2007, 10:17:44 AM (16 years ago)
v3 v4 3 3 It only uses straight CSS and HTML, with no fancy !JavaScript of Jx layout components other than what is contained in Fusion. 4 4 5 To install this (on Windows) unzip the contents of the [ [/mapguide/attachment/wiki/CodeSamples/Fusion/SuperSimple/supersimple.zip?format=raw attached file]] into the following directory:5 To install this (on Windows) unzip the contents of the [/mapguide/attachment/wiki/CodeSamples/Fusion/SuperSimple/supersimple.zip?format=raw attached zipfile] into the following directory: 6 6 7 7 {{{ … … 12 12 }}} 13 13 14 You can then access this as (changing your hostname and port as required): 15 16 {{{ 17 18 19 http://localhost:8008/fusion/samples/mapguide/supersimple/index.html 20 21 }}} 22 23 14 24 Once you are familiar with this minimalist application, it is worth looking at the index.html files in the bundled Fusion templates to see what Jx can do; it's where Fusion's dynamic layout capabilities comes from. 15 25
