Changes between Version 2 and Version 3 of CodeSamples/Fusion/SuperSimple
- Dec 18, 2007, 10:14:59 AM (16 years ago)
v2 v3 1 1 This is an example of an extremely simple Fusion application. 2 2 3 It only uses straight CSS and HTML, with no fancy JavaScript of Jx layout components other than what is contained in Fusion.3 It only uses straight CSS and HTML, with no fancy !JavaScript of Jx layout components other than what is contained in Fusion. 4 4 5 To install this (on Windows) unzip the contents of the attached fileinto the following directory:5 To install this (on Windows) unzip the contents of the [[/mapguide/attachment/wiki/CodeSamples/Fusion/SuperSimple/supersimple.zip?format=raw attached file]] into the following directory: 6 6 7 7 {{{
