Changes between Version 5 and Version 6 of AdvancedStylization
- Dec 13, 2009, 3:05:31 PM (14 years ago)
AdvancedStylization
v5 v6 11 11 * The [wiki:MapGuideRfc14 RFC] itself, including the attached !LineUsage.doc 12 12 13 * The I magine-IT [http://www.rand.com/imaginit/1/pdfs/technology/software/building_symbol_libraries_with_autodesk_mapguide_enterprise_2009.pdf Building Symbol Libraries] PDF is helpful13 * The IMAGINiT [http://www.rand.com/imaginit/1/pdfs/technology/software/building_symbol_libraries_with_autodesk_mapguide_enterprise_2009.pdf Building Symbol Libraries] PDF is helpful 14 14 15 15 * In a bind, you need to be able to read and understand the [/mapguide/browser/branches/2.1/MgDev/Common/Schema/LayerDefinition-1.3.0.xsd LayerDefinition] and [/mapguide/browser/branches/2.1/MgDev/Common/Schema/SymbolDefinition-1.1.0.xsd SymbolDefinition] schemas 16 16 17 * XPS ([http://www.microsoft.com/whdc/xps/xpsspecdwn.mspx XML Paper Specification]) - has information about the specific geometry syntax (e.g., how to draw a line or arc); see section 4.2.3 Abbreviated Geometry Syntax to see the geometry syntax that we use. The I magine-IT document describes the subset that we support.17 * XPS ([http://www.microsoft.com/whdc/xps/xpsspecdwn.mspx XML Paper Specification]) - has information about the specific geometry syntax (e.g., how to draw a line or arc); see section 4.2.3 Abbreviated Geometry Syntax to see the geometry syntax that we use. The IMAGINiT document describes the subset that we support. 18 18 19 19 == Sample Packages ==
