Changes between Version 10 and Version 11 of 1.2to2.0MigrationInstructions
- Dec 13, 2007, 1:41:24 PM (16 years ago)
v10 v11 8 8 2. Change to the !RepositoryAdmin directory (e.g. "C:\Program Files\!MapGuideOpenSource\Server\!RepositoryAdmin" on Windows). 9 9 10 3. Run !BackUpOnlineRepositories.bat (or !BackUpOnlineRepositories.sh for Linux). 10 3. Run !BackUpOnlineRepositories.bat (or !BackUpOnlineRepositories.sh for Linux). '''Important: ensure that you do not use !BackUpOfflineRepositories.bat/sh here otherwise the next step will fail.''' 11 11 12 4. Run !RestoreRepositories.bat (or !RestoreRepositories.sh for Linux). 12 4. Run !RestoreRepositories.bat (or !RestoreRepositories.sh for Linux). Check the output to make sure there are no errors. 13 13 14 5. Windows: uninstall the 1.2 server (note that this does not delete the existing repositories). Or stop the server and try out the instructions for a side-by-side install: http://trac.osgeo.org/mapguide/wiki/InstallSideBySide1.2and2.0Apache.14 5. Windows: uninstall the 1.2 server (note that this does not delete the existing repositories). Or stop the server and try out the instructions for a side-by-side install: [wiki:InstallSideBySide1.2and2.0Apache side by side install]. 15 15 16 16 6. Install the new MGOS 2.0 Server. Note that the server will fail to start if it tries to open old repositories.
