Changes between Initial Version and Version 1 of Ticket #606
Jun 13, 2008, 10:41:38 AM (16 years ago)
jbirch
  • Ticket #606 – Description
    initial v1
    1 It would be useful to be able to click on a Layer and say "Point all maps that reference this layer to this other layer instead", and the same for MapDefinitions (and WebLayouts/ApplicationDefinitions).
     1It would be useful to be able to click on a Layer and say "Point all maps that reference this layer to this other layer instead", and the same for !MapDefinitions (and !WebLayouts/ApplicationDefinitions).  This would allow for simple testing of new layer definitions before swapping into live maps.
    3 Similar option would be cool for data connections as well, but much more complex because of potential for mis-matched schemas.  To implement this you would also need to have a validity checker for layer definitions, allowing the user to list layers with invalid definitions, and visually see which properties are invalid when the layer is open.  MapGuide Studio (at least up to 2008?) just resets the layer definition when there are different schemas regardless of whether it would invalidate the layer definition, but this is not a desirable behaviour.
     3Similar option would be cool for data connections as well, but much more complex because of potential for mis-matched schemas.  To implement this you would also need to have a validity checker for layer definitions, allowing the user to list layers with invalid definitions, and visually see which properties are invalid when the layer is open.  !MapGuide Studio (at least up to 2008?) just resets the layer definition when there are different schemas regardless of whether it would invalidate the layer definition, but this is not a desirable behaviour.
