Changes between Initial Version and Version 1 of Ticket #1642
Mar 25, 2011, 4:25:21 AM (13 years ago)
jng
  • Ticket #1642 – Description
    initial v1
    1 The Category view in the New Resource Dialog is a bit cumbersome as the Available Templates view will only show templates for the selected category. I'd guess most users won't realise that you can create a SQLite load procedure because it's hidden in a separate category that most users probably won't select.
     1The Category view in the New Resource Dialog is a bit cumbersome as the Available Templates view will only show templates for the selected category. For example, I'd guess most users won't realise that you can create a SQLite load procedure because it's hidden in a separate category (MGOS 2.2) that most users probably won't select.
    33Instead the Category View should be a checked list box, with the Available Templates view being filtered on what's checked in the Category View. By default, all categories should be checked meaning all templates are visible.
