Changes between Initial Version and Version 2 of Ticket #1597
- Feb 4, 2011, 4:02:06 PM (13 years ago)
Ticket #1597
- Property Owner set to
- Property Summary Remove memory size restriction on MgByte → Remove 16MB memory size restriction on MgByte
Ticket #1597 – Description
initial v2 1 With 64bit support and systems with more memory available today the original 16MB restriction on MgByte is no longer needed. Also in some cases this actually causes an error when theming on a large number of features because 16MB is not large enough to contain all of the data.1 With 64bit support and systems with more memory available today the original 16MB restriction on !MgByte is no longer needed. Also in some cases this actually causes an error when theming on a large number of features because 16MB is not large enough to contain all of the data.
