Changes between Initial Version and Version 2 of Ticket #1077
- Aug 28, 2009, 9:47:53 AM (15 years ago)
Ticket #1077
- Property Owner set to
- Property Status new → assigned
Ticket #1077 – Description
initial v2 1 The GCC 4.x compiler generates code that causes the built libMapGuideJavaApi.so to crash TomCat when the Java viewer is used.1 The GCC 4.x compiler generates code that causes the built libMapGuideJavaApi.so to crash !TomCat when the Java viewer is used. 2 2 3 3 The fix for this is that the SWIG generated code needs to be compiled with the following compiler setting:
