Changes between Version 10 and Version 11 of GSoC/2014/TestingFrameworkForGRASS
- May 23, 2014, 3:20:15 PM (10 years ago)
v10 v11 212 212 Tests (suites, cases, or scripts/modules) itself can define in which location or locations they should be executed as a global variable (both for unit and doctests, doctests in they their unittest wrapper). The global variable will be ignored in case the test script is executed by hand. When executed by make system, the test can be executed in all locations specified by the global variable, or one location specified by make system (or generally forced from the top). In other words, the global variable specifies what the test want to do, not what it is capable to do because we want it to run in any location. 213 213 214 We should have dedicated test locations with different projections and identical map names. I wouldn't use the GRASS sample locations (NC, Spearfish) as test locations directly. We should have dedicated test locations with selected data (they can overlap with let's say NC but may contain less imagery but some additional strange data). The only difference between the locations would be the projection, so it really makes difference only for projected, latlon and perhaps XY.214 We should have dedicated test locations with different projections and identical map names. I wouldn't use the GRASS sample locations (NC, Spearfish) as test locations directly. We should have dedicated test locations with selected data. They can overlap with (let's say) NC but may contain less imagery but on the other hand some additional strange data. The complication are doctests which are documentation, so as a consequence they should use the intersection of NC sample and testing location. The only difference between the locations would be the projection, so it really makes difference only for projected, latlon and perhaps XY. 215 215 216 216 If multiple locations are allowed and we expect some maps being in the location such as elevation raster, it is not clear how to actually test the result such as aspect computed from elevation since the result (such as MD5 sum) will be different for each location/projection. This would mean that the checking/assert functions or tests themselves would have to handle different locations and moreover, this type of tests would always fail in the user provided location.
