Changes between Initial Version and Version 1 of BoundingBoxFromKeyword
Mar 25, 2010, 1:27:09 AM (14 years ago)
fxp
  • BoundingBoxFromKeyword
     1|| '''Date''' || 2010/03/25 ||
     2|| '''Contact(s)''' || Francois ||
     3|| '''Last edited''' || [[Timestamp]] ||
     4|| '''Status''' || Draft ||
     5|| '''Assigned to release''' || 2.5 ||
     6|| '''Resources''' || GéoSource [BRGM] ||
     7|| '''Ticket''' ||  ||
     8
     9== Overview ==
     10This proposal allows editor to add extent information based on keyword analysis.
     11In the editor a button is added to run the process :
     12 1. For each keywords
     13 1. Search for the keyword in thesaurus
     14 1. If keyword in the thesaurus has an extent
     15 1. Add an extent with a description and a bounding box to the metadata record.
     16
     17The process could be run in 2 modes :
     18 * Add : Keep existing extent elements and add the new one at the end. Editor could clean the section after processing.
     19 * Replace : Remove all extent having only a bounding box (temporal, vertical and bounding polygon are not removed), and add the new one at the end.
     20
     21
     22=== Select your keywords ===
     23
     24[[Image(bboxk-selectkeyword.png)]]
     25
     26=== In edit mode, 2 new actions ===
     27[[Image(bboxk-button.png)]]
     28
     29=== After processing ===
     30[[Image(bboxk-results.png)]]
     31
     32
     34
     35
     36=== Proposal Type ===
     37 * '''Type''': GUI
     38 * '''App''': !GeoNetwork
     39 * '''Module''': GUI
     40
     41=== Links ===
     42
     43 * '''Email discussions''':
     44 * '''IRC discussions''':
     45
     46=== Voting History ===
     47 * Vote proposed by Francois the 22nd march 2010
     48
     49== Proposal details ==
     50Default configuration parameter is equivalent to current GeoNetwork behavior.
     51
     52Parameters are defined in config-gui.xml :
     53{{{
     54<!-- Display or not category information : Categories are stored in the database and a metadata
     55 record could be linked to one or more categories. -->
     56 <category>
     57  <!--
     58   To disable that feature
     59   comment this out. This will hide categories in search criteria,
     60   metadata editing and administration interface.
     61  -->
     62  <admin/>
     63
     64  <!-- Display category as icon in search results. Categories could be :
     65    * define from category table or
     66    * define based on schema : iso19139 could be service or dataset and iso19110 is feature catalogue (internal category)
     67
     68  mode attribute could be:
     69   * all : all categories
     70   * db : only from category table
     71   * internal : only internal category
     72
     73  <display-in-search mode="db"/>
     74   -->
     75 </category>
     76}}}
     78
     79Icons could be added to images/category directory.
     80
     81
     82== Backwards Compatibility Issues ==
     83None.
     84
     85== Risks ==
     86
     87== Participants ==
     88 * Francois
