1 | | I'm using the c# binding. one of the Gdal.wrapper_GDALWarpDestName parameters is of type SWIGTYPE_p_p_GDALDatasetShadow. shouldn't it be of type Dataset[]? what is the way to use it? |
| 1 | I'm using the c# binding.all methods that should get as argument Dataset[], actually expects type SWIGTYPE_p_p_GDALDatasetShadow instead. |
| 2 | this happens in the following methods:\\ |
| 3 | Gdal.CreatePansharpenedVRT(...)\\ |
| 4 | Gdal.wrapper_GDALBuildVRT_objects(...)\\ |
| 5 | Gdal.wrapper_GDALWarpDestDS(...)\\ |
| 6 | Gdal.wrapper_GDALWarpDestName(...)\\ |
| 7 | \\ |
| 8 | moreover, the method Gdal.wrapper_GDALVectorTranslateDestDS(...) expect to get Datasets (src & dst) while it should get Datasource (vector) isn't it? |
