Changes between Initial Version and Version 1 of Ticket #4489
- Feb 3, 2012, 2:52:41 PM (12 years ago)
Ticket #4489 – Description
initial v1 1 1 I'm not sure if this is the exact same problem as bug #2550, but I thought I would flag it regardless. 2 2 3 Using version 1.9 and processing a GRIB file results in the output being wrong in the sense that values >180 should actually be <180 degrees.3 Using version 1.9 and processing a GRIB file results in the output being wrong in the sense that values >180 degrees should actually be <0 degrees. 4 4 5 5 The attached screenshot might illustrate this better. Generating she shapefile using the following command:
