Changes between Initial Version and Version 2 of Ticket #1389
- Mar 26, 2007, 9:03:50 PM (17 years ago)
Ticket #1389
- Property Component default → OGR_SF
- Property Priority highest → normal
- Property Milestone → 1.4.1
- Property Owner changed from to
- Property Severity blocker → normal
Ticket #1389 – Description
initial v2 1 2 the SQL generated by ogr2ogr seems to be truncating the date field. The record has the correct date using "ogrinfo -al". Problem reproduced on linux (RHEL WS 4) and Mac (10.4). Sample shapefile available at http://mapdevel.ngdc.noaa.gov/sample.tar 1 3 {{{ 2 the SQL generated by ogr2ogr seems to be truncating the date field. The record has the correct date using "ogrinfo -al". Problem reproduced on linux (RHEL WS 4) and Mac (10.4). Sample shapefile available at http://mapdevel.ngdc.noaa.gov/sample.tar3 4 4 e.g. 5 5 lynx:/usr/local/shapefiles jcc$ ogr2ogr -f postgresql -a_srs EPSG:4326
