Changes between Version 1 and Version 2 of java-pacaging
- 08/18/14 06:55:07 (11 years ago)
TabularUnified java-pacaging
v1 v2 25 25 26 26 The most complicated things about this approach is converting the project to maven, if it has many dependencies this can take a while. Off course, you can use IDE like Eclipse or IntelliJ Idea to help you make the conversion. Once it is maven compatible, Maven-Debian-Helper is pretty straight forward. 27 28 You can find a simple example of a package made using Maven-Debian-Helper here: https://scm.lan.mapgears.com/packages/debian/jsr-275
