Changes between Version 2 and Version 3 of TutorialMrSid
- Jul 3, 2009, 3:45:56 PM (15 years ago)
TutorialMrSid
v2 v3 5 5 If you have not already, add the Ubuntu GIS repository to apt sources list. See this page for instructions: [wiki:UbuntuGISRepository Adding Ubuntu GIS repository to your system's software sources] 6 6 7 '''1. Compiling and installing Geo-DSDK'''7 '''1. Installing the SDK''' 8 8 9 9 Download the software development kit (SDK) from LizardTech, the company that owns the MrSID patents. Go to this web site (http://www.lizardtech.com/developer/ ), register for a developer account (which is free of charge), and download the version of the Linux SDK that matches your architecture (32 bit or 64 bit) and your version of the Gnu C Compiler (gcc) – for recent Ubuntu distributions (8.04, 8.10, 9.04) the gcc 4.1 versions will work. … … 45 45 gdalinfo --formats | grep -i mrsid 46 46 47 You should see “MrSID (ro): Multi-resolution Seamless Image Database (MrSID)” and “JP2MrSID (ro): MrSID JPEG2000”. These lines indicate that both MrSID and JPEG2000 support have been added to GDAL (note that there is a free software implementation of JPEG2000 support through the Jasper library, but support for JPEG2000 is also available using the LizardTech SDK).47 You should see "MrSID (ro): Multi-resolution Seamless Image Database (MrSID)" and "JP2MrSID (ro): MrSID JPEG2000". These lines indicate that both MrSID and JPEG2000 support have been added to GDAL (note that there is a free software implementation of JPEG2000 support through the Jasper library, but support for JPEG2000 is also available using the LizardTech SDK). 48 48 49 49 Example images are distributed with the SDK – you can further check whether compilation was successful with:
