Changes between Version 2 and Version 3 of TracBatchModify
- 05/08/22 15:13:24 (3 years ago)
TabularUnified TracBatchModify
v2 v3 2 2 [[TracGuideToc]] 3 3 4 Trac supports modifying a batch of tickets in one request from [TracQuery custom query] results. 4 Trac supports modifying a batch of tickets in one request from [TracQuery custom query] results. The Batch Modify functionality only appears on Query pages (/query), not Report pages (/report). You must have !JavaScript enabled in your browser. 5 5 6 To perform a batch modification, select the tickets you wish to modify and set the new field values using the section underneath the query results. 6 To perform a batch modification, select the tickets you wish to modify and set the new field values using the section underneath the query results. 7 7 8 8 == List fields 9 9 10 The `Keywords` and `Cc` fields are treated as lists, where list items can be added and/or removed in addition ofreplacing the entire list value. All list field controls accept multiple items, such as multiple keywords or cc addresses.10 The `Keywords` and `Cc` fields are treated as lists, where list items can be added and/or removed, as well as replacing the entire list value. All list field controls accept multiple items, such as multiple keywords or cc addresses. 11 11 12 12 == Excluded fields 13 13 14 Multi-line text fields are not supported, because no valid use-case has been presented for syncing them across several tickets. That restriction applies to the `Description` field as well as to any [TracTicketsCustomFields#AvailableFieldTypesandOptions custom field] of type 'textarea'. However, future versions of Trac could support in conjunction with more suitable actions like 'prepend', 'append' or 'search & replace' ([http://trac-hacks.org/ticket/2415 th:#2415]).14 Multi-line text fields are not supported, because no valid use-case has been presented for syncing them across several tickets. That restriction applies to the `Description` field as well as to any [TracTicketsCustomFields#AvailableFieldTypesandOptions custom field] of type 'textarea'. However, future versions of Trac could support batch modification of textareas in conjunction with more suitable actions like 'prepend', 'append' or 'search & replace' ([trac:#11197]).
