Changes between Initial Version and Version 1 of TracAdmin
May 19, 2009, 8:26:53 AM (15 years ago)
  • TracAdmin
     1= TracAdmin =
     2[[TracGuideToc]]
     4Trac is distributed with a powerful command-line configuration tool. This tool can be used  to configure and customize your Trac-installation to better fit your needs.
     6Some of those operations can also be performed via the web interface thanks to the optional [http://trac.edgewall.org/wiki/WebAdmin WebAdmin] plugin, distributed separately for now.
     8== Usage ==
     10You can get a comprehensive list of the available options, commands and sub-commands by invoking `trac-admin` with the `help` command:
     11{{{
     12trac-admin help
     13}}}
     14
     15Unless you're executing the `help`, `about` or `version` sub-commands, you'll need to specify the path to the TracEnvironment that you want to administer as the first argument, for example:
     16{{{
     17trac-admin /path/to/projenv wiki list
     18}}}
     19
     20== Interactive Mode ==
     21
     22When passing the environment path as the only argument, `trac-admin` starts in interactive mode.
     23Commands can then be executed on the selected environment using the prompt, which offers tab-completion
     24(on non-Windows environments, and when the Python `readline` module is available) and automatic repetition of the last command issued.
     25
     26Once you're in interactive mode, you can also get help on specific commands or subsets of commands:
     27
     28For example, to get an explanation of the `resync` command, run:
     29{{{
     30> help resync
     31}}}
     32
     33To get help on a all the Wiki-related commands, run:
     34{{{
     35> help wiki
     36}}}
     37
     38----
     39See also: TracGuide, TracBackup, TracPermissions, TracEnvironment, TracIni
