Changes between Version 5 and Version 6 of EnvironmentSetup
- Aug 19, 2013, 8:26:54 AM (11 years ago)
EnvironmentSetup
v5 v6 52 52 I suggest using the /vagrant/packages directory (~/vm/ubuntugis/packages on the host) for your packages, that way you can edit some files from the host and only use Vagrant for the packaging/build. 53 53 54 The pbuilder-dist environment that were setup by the bootstrap script are SID, Lucid, Precise, Quantal and Raring each in i386 and amd64.54 The pbuilder-dist environments that were setup by the bootstrap script are SID, Lucid, Precise, Quantal and Raring each in i386 and amd64.
