Changes between Version 1 and Version 2 of EnvironmentSetup
- Aug 19, 2013, 7:59:12 AM (11 years ago)
EnvironmentSetup
v1 v2 9 9 vagrant up 10 10 }}} 11 {{{vagrant up}}}will take care of installing everything you need for packaging.12 Once it's done you can access the vm with 'vagrant ssh'.11 "{{{vagrant up}}}" will take care of installing everything you need for packaging. 12 Once it's done you can access the vm with "{{{vagrant ssh}}}". 13 13 14 14 5. We need to setup the GPG key to sign the packages in the VM. … … 46 46 allow_unsigned_uploads = 0 47 47 }}} 48 This will let you upload using {{{dput ubuntugis-unstable package_sources.changes}}}48 This will let you upload using "{{{dput ubuntugis-unstable package_sources.changes}}}" 49 49 50 50
