Changes between Version 6 and Version 7 of UserGuide
- Jul 10, 2008, 1:12:29 PM (16 years ago)
UserGuide
v6 v7 1 1 = User Guide = 2 3 == Basics == 2 4 3 5 Using Proj4js is a matter of: … … 42 44 Proj4js uses the same initialization parameters that [wiki:proj PROJ.4] uses and these values must be defined before the constructor is called. 43 45 44 == If you know the projections to be used in your application==46 === If you know the projections to be used in your application === 45 47 46 48 You can define these via the script tag (see examples in the lib/defs directory) or anywhere else in your application. … … 50 52 }}} 51 53 52 == Dynamic lookup of initialization parameters==54 === Dynamic lookup of initialization parameters === 53 55 54 56 If you don't know the CRS's to be used by the application, Proj4js can dynamically look up the initialization parameters at run-time. By default, it will use the REST web service at [http://spatialreference.org spatialreference.org] as the lookup service.
