Changes between Version 1 and Version 2 of TracCgi
- 06/10/10 13:36:32 (15 years ago)
TracCgi
v1 v2 1 1 = Installing Trac as CGI = 2 2 3 To install Trac as a CGI script, you need to make the `trac.cgi` executable as a CGI by your web server. 3 {{{ 4 #!div class=important 5 ''Please note that using Trac via CGI is the slowest deployment method available. It is slower than [TracModPython mod_python], [TracFastCgi FastCGI] and even [trac:TracOnWindowsIisAjp IIS/AJP] on Windows.'' 6 }}} 4 7 5 ''Please note that using Trac via CGI is significantly slower than any other deployment method, such as [TracModPython mod_python] or [TracFastCgi FastCGI].'' 8 CGI script is the entrypoint that web-server calls when a web-request to an application is made. To generate the `trac.cgi` script run: 9 {{{ 10 trac-admin /path/to/env deploy /path/to/www/trac 11 }}} 12 `trac.cgi` will be in the `cgi-bin` folder inside the given path. Make sure it is executable by your web server. This command also copies `static resource` files to a `htdocs` directory of a given destination. 6 13 7 If you're using [http://httpd.apache.org/ Apache HTTPD], there are a couple ways to do that: 14 == Apache web-server configuration == 8 15 9 1. Use a `ScriptAlias` to map a URL to the `trac.cgi` script 16 In [http://httpd.apache.org/ Apache] there are two ways to run Trac as CGI: 17 18 1. Use a `ScriptAlias` directive that maps an URL to the `trac.cgi` script (recommended) 10 19 2. Copy the `trac.cgi` file into the directory for CGI executables used by your web server (commonly named `cgi-bin`). You can also create a symbolic link, but in that case make sure that the `FollowSymLinks` option is enabled for the `cgi-bin` directory. 11 20 12 The first option is recommended as it also allows you to map the CGI to a friendly URL. 13 14 Now, edit the Apache configuration file and add this snippet, file names and locations changed to match your installation: 21 To make Trac available at `http://yourhost.example.org/trac` add `ScriptAlias` directive to Apache configuration file, changing `trac.cgi` path to match your installation: 15 22 {{{ 16 ScriptAlias /trac / usr/share/trac/cgi-bin/trac.cgi23 ScriptAlias /trac /path/to/www/trac/cgi-bin/trac.cgi 17 24 }}} 18 25 19 ''Note that this directive requires the `mod_alias` module to be installed and enabled.''26 ''Note that this directive requires enabled `mod_alias` module.'' 20 27 21 28 If you're using Trac with a single project you need to set its location using the `TRAC_ENV` environment variable: … … 33 40 }}} 34 41 35 ''Note that the `SetEnv` directive requires the `mod_env` module to be installed and enable.''42 ''Note that the `SetEnv` directive requires enabled `mod_env` module. It is also possible to set TRAC_ENV in trac.cgi. Just add the following code between "try:" and "from trac.web ...":'' 36 43 37 This will make Trac available at `http://yourhost.example.org/trac`. 44 {{{ 45 import os 46 os.environ['TRAC_ENV'] = "/path/to/projectenv" 47 }}} 48 49 '' Or for TRAC_ENV_PARENT_DIR: '' 50 51 {{{ 52 import os 53 os.environ['TRAC_ENV_PARENT_DIR'] = "/path/to/project/parent/dir" 54 }}} 38 55 39 56 If you are using the [http://httpd.apache.org/docs/suexec.html Apache suEXEC] feature please see [http://trac.edgewall.org/wiki/ApacheSuexec]. … … 43 60 == Mapping Static Resources == 44 61 45 Out of the box, Trac will serve static resources such as style sheets or images itself. For a CGI setup, though, this is highly undesirable, because it results in the CGI script being invoked for documents that could be much more efficiently served by the web server directly.62 Out of the box, Trac will pass static resources such as style sheets or images through itself. For a CGI setup this is '''highly undesirable''', because this way CGI script is invoked for documents that could be much more efficiently served directly by web server. 46 63 47 Web servers such as [http://httpd.apache.org/ Apache HTTPD] allow you to create “Aliases” to resources, thereby giving them a virtual URL that doesn't necessarily bear any resemblance to the layout of the servers file system. We already used this capability above when defining a `ScriptAlias` for the CGI script, and we'll use it now to map requests to the static resources to the directory on the file system that contains them, thereby bypassing the processing of such requests by theCGI script.64 Web servers such as [http://httpd.apache.org/ Apache] allow you to create “Aliases” to resources, giving them a virtual URL that doesn't necessarily reflect the layout of the servers file system. We already used this capability by defining a `ScriptAlias` for the CGI script. We also can map requests for static resources directly to the directory on the file system, avoiding processing these requests by CGI script. 48 65 49 Edit the Apache configuration file again and add the following snippet '''before''' the `ScriptAlias` for the CGI script , file names and locations changed to match your installation:66 Add the following snippet to Apache configuration '''before''' the `ScriptAlias` for the CGI script, changing paths to match your deployment: 50 67 {{{ 51 Alias /trac/chrome/common / usr/share/trac/htdocs52 <Directory "/ usr/share/trac/htdocs">68 Alias /trac/chrome/common /path/to/www/trac/htdocs 69 <Directory "/path/to/www/trac/htdocs"> 53 70 Order allow,deny 54 71 Allow from all … … 56 73 }}} 57 74 58 Note that w hatever URL path you mapped the `trac.cgi` script to,the path `/chrome/common` is the path you have to append to that location to intercept requests to the static resources.75 Note that we mapped `/trac` part of the URL to the `trac.cgi` script, and the path `/chrome/common` is the path you have to append to that location to intercept requests to the static resources. 59 76 60 77 For example, if Trac is mapped to `/cgi-bin/trac.cgi` on your server, the URL of the Alias should be `/cgi-bin/trac.cgi/chrome/common`. 61 78 62 Alternatively, you can set the `htdocs_location` configuration option in [wiki:TracIni trac.ini]: 79 Similarly, if you have static resources in a project's htdocs directory (which is referenced by /chrome/site URL in themes), you can configure Apache to serve those resources (again, put this '''before''' the `ScriptAlias` for the CGI script, and adjust names and locations to match your installation): 80 81 {{{ 82 Alias /trac/chrome/site /path/to/projectenv/htdocs 83 <Directory "/path/to/projectenv/htdocs"> 84 Order allow,deny 85 Allow from all 86 </Directory> 87 }}} 88 89 Alternatively to hacking `/trac/chrome/site`, you can directly specify path to static resources using `htdocs_location` configuration option in [wiki:TracIni trac.ini]: 63 90 {{{ 64 91 [trac] 65 htdocs_location = /trac-htdocs92 htdocs_location = http://yourhost.example.org/trac-htdocs 66 93 }}} 67 94 68 95 Trac will then use this URL when embedding static resources into HTML pages. Of course, you still need to make the Trac `htdocs` directory available through the web server at the specified URL, for example by copying (or linking) the directory into the document root of the web server: 69 96 {{{ 70 $ ln -s / usr/share/trac/htdocs /var/www/your_site.com/htdocs/trac-htdocs97 $ ln -s /path/to/www/trac/htdocs /var/www/yourhost.example.org/trac-htdocs 71 98 }}} 99 100 Note that in order to get this `htdocs` directory, you need first to extract the relevant Trac resources using the `deploy` command of TracAdmin: 101 [[TracAdminHelp(deploy)]] 102 72 103 73 104 == Adding Authentication == … … 113 144 }}} 114 145 115 For better security, it is recommended that you either enable SSL or at least use the “Digest” authentication scheme instead of “Basic”. Please read the [http://httpd.apache.org/docs/2.0/ Apache HTTPD documentation] to find out more. 146 For better security, it is recommended that you either enable SSL or at least use the “digest” authentication scheme instead of “Basic”. Please read the [http://httpd.apache.org/docs/2.0/ Apache HTTPD documentation] to find out more. For example, on a Debian 4.0r1 (etch) system the relevant section in apache configuration can look like this: 147 {{{ 148 <Location "/trac/login"> 149 LoadModule auth_digest_module /usr/lib/apache2/modules/mod_auth_digest.so 150 AuthType Digest 151 AuthName "trac" 152 AuthDigestDomain /trac 153 AuthUserFile /somewhere/trac.htpasswd 154 Require valid-user 155 </Location> 156 }}} 157 and you'll have to create your .htpasswd file with htdigest instead of htpasswd as follows: 158 {{{ 159 # htdigest /somewhere/trac.htpasswd trac admin 160 }}} 161 where the "trac" parameter above is the same as !AuthName above ("Realm" in apache-docs). 116 162 117 163 ---- 118 See also: TracGuide, TracInstall, TracFastCgi, TracModPython164 See also: TracGuide, TracInstall, [wiki:TracModWSGI], TracFastCgi, TracModPython
