Changes between Version 5 and Version 6 of DevGuide
- Sep 16, 2013, 11:55:40 AM (11 years ago)
DevGuide
v5 v6 14 14 * https://svn.codehaus.org/mapbuilder/tags/mapbuilder-lib-1_0-release/mapbuilder/lib/model/Proj.js 15 15 16 == Building custom versions of Proj4js == 16 == Building Proj4js == 17 === 1.3.1 and later === 18 See https://github.com/proj4js/proj4js#developing 17 19 18 NOTE: The following instructions apply to the latest Proj4js release. The build system on master is currently being rewritten. 19 20 === 1.1.0 === 20 21 The proj4js/build directory contains some scripts that can be use to build a single file (buildUncompressed.py) and compressed (build.py) versions of the Proj4js library. The build process is controlled by the file library.cfg. To build the library: 21 22 {{{
