Changes between Version 1 and Version 2 of WikiStart
- Apr 10, 2009, 10:03:55 AM (15 years ago)
WikiStart
v1 v2 1 = Welcome to Trac 0.10 =1 = PostGIS Tracker and Wiki = 2 2 3 Trac is a '''minimalistic''' approach to '''web-based''' management of 4 '''software projects'''. Its goal is to simplify effective tracking and handling of software issues, enhancements and overall progress. 3 This Trac instance is used for bug, enhancement & task tracking, a user and developer wiki, and a view into the subversion code repository. To edit the wiki pages and bug/enhancement/task tickets you'll need to login with an [http://www.osgeo.org/osgeo_userid OSGeo Userid]. Read the TracGuide for details about how the site works. 5 4 6 All aspects of Trac have been designed with the single goal to 7 '''help developers write great software''' while '''staying out of the way''' 8 and imposing as little as possible on a team's established process and 9 culture. 5 == Bug Tracking == 10 6 11 As all Wiki pages, this page is editable, this means that you can 12 modify the contents of this page simply by using your 13 web-browser. Simply click on the "Edit this page" link at the bottom 14 of the page. WikiFormatting will give you a detailed description of 15 available Wiki formatting commands. 7 * [/postgis/newticket Submit a new bug report] (you need to [http://trac.osgeo.org/postgis/login login] with an [http://www.osgeo.org/osgeo_userid OSGeo Userid]) 8 * [query:status!=closed&type=defect&order=id&desc=1 List Open Bugs] 9 * [query:status!=closed&type=enhancement&order=id&desc=1,compact List Open Enhancement Requests] 16 10 17 "[wiki:TracAdmin trac-admin] ''yourenvdir'' initenv" created 18 a new Trac environment, containing a default set of wiki pages and some sample 19 data. This newly created environment also contains 20 [wiki:TracGuide documentation] to help you get started with your project. 11 == User Wiki == 21 12 22 You can use [wiki:TracAdmin trac-admin] to configure 23 [http://trac.edgewall.org/ Trac] to better fit your project, especially in 24 regard to ''components'', ''versions'' and ''milestones''. 13 * To be done... 25 14 15 == Developer Wiki == 26 16 27 TracGuide is a good place to start.17 * To be done... 28 18 29 Enjoy! [[BR]] 30 ''The Trac Team'' 31 32 == Starting Points == 19 == Trac Documentation == 33 20 34 21 * TracGuide -- Built-in Documentation
