Changes between Version 3 and Version 4 of WikiPageNames
- 02/01/17 00:39:16 (8 years ago)
TabularUnified WikiPageNames
v3 v4 19 19 and with a label: [wiki:"Space Matters" all about white space] 20 20 * or simply: ["WikiPageName"]s 21 * even better, the new[[WikiCreole link style]]21 * even better, the [[WikiCreole link style]] 22 22 and with a label: [[WikiCreole link style|WikiCreole style links]] 23 23 }}} … … 29 29 and with a label: [wiki:"Space Matters" all about white space] 30 30 * or simply: ["WikiPageName"]s 31 * even better, the new[[WikiCreole link style]]31 * even better, the [[WikiCreole link style]] 32 32 and with a label: [[WikiCreole link style|WikiCreole style links]] 33 33 34 34 It is possible to link to a specific ''version'' of a Wiki page as you would do for a specific version of a file, for example: WikiStart@1. 35 35 36 You can alsoprevent a !CamelCase name from being interpreted as a [TracLinks link] by quoting it with an exclamation mark: `!CamelCase`. See TracLinks#EscapingLinks.36 You can prevent a !CamelCase name from being interpreted as a [TracLinks link] by quoting it with an exclamation mark: `!CamelCase`. See TracLinks#EscapingLinks. 37 37 38 As in the example above, you can also append an anchor to a Wiki page name to link to a specific section within that page. The anchor can be seen by hovering the mouse over a section heading, then clicking on the [[html(¶)]] sign that appears at its end. The anchor is usually generated automatically, but it is also possible to specify it explicitly: see WikiFormatting#using-explicit-id-in-heading. 38 As in the example above, you can append an anchor to a Wiki page name to link to a specific section within that page. The anchor can be seen by hovering the mouse over a section heading, then clicking on the [[html(¶)]] sign that appears at its end. The anchor is usually generated automatically, but it is also possible to specify it explicitly: see WikiFormatting#using-explicit-id-in-heading. 39 40 There are a few options that govern the rendering of WikiPageNames: 41 * CamelCase linking to missing pages can be disabled with the `ignore_missing_pages` [https://trac.edgewall.org/wiki/TracIni#wiki-section option]. Linking to missing pages is enabled by default. 42 * The `split_page_names` option, when enabled, will split CamelCase words when rendering a link. For example, WikiStart will be rendered as [WikiStart Wiki Start]. 39 43 40 44 ----
