Changes between Version 236 and Version 237 of WKTRaster/SpecificationWorking03
08/27/12 11:29:41 (12 years ago)
pracine
  • WKTRaster/SpecificationWorking03
    v236 v237
    7777''Note that accomplished objectives have been moved at the bottom of the page.''
    7878
    79 == '''Objective FV.24 - ST_MapAlgebraFctNbg() working on a tiled coverage''' ==
    80
    81
    82 '''ST_MapAlgebraFctNgb('''rasttable text, rastcolumn text, band int, pixeltype text, radius int, funcname text[, funcargs text]''') -'''
    83
    84  A one raster version taking a '''table name and a raster column name''' (in order to work on a '''tiled coverage''') and a '''user defined function''' (with optional parameters) of the set of first, second, etc... '''neighbours''' of a pixel. This version work transparently on a tiled coverage avoiding edges effects.
    85
    86  The function could 1) search itself for out of bound pixel values or 2) pass the name of the table to search for those values and let this job to the custom function. (I think 1) is a better option since the actual predefined custom functions would work tranparently).
    87
    88  Open question: What to do when there are more than one pixel (because they are overlapping) value neighbouring the current pixel? Could be another parameter saying take the 'MIN', the 'MAX', the 'FIRST', the 'LAST', the 'MEAN'...
    89
    90  See also: [wiki:WKTRaster/MapAlgebra Notes taken by David Zwarg during the Montreal Code Sprint 2011] and ticket #860.
    91
    92 ----
    93 == '''Objective FV.25 - Optimized version of two rasters ST_MapAlgebra()''' ==
    94
    95  * ST_MapAlgebra(raster, raster, 'UNION') can be optimized by not iterating on every pixels when it is not necessary. "Chunk" (or large areas) of pixels, outside the intersecting area of the two raster can be set in a "memset manner".
    96
    97  * The prototype of an optimized version, trying to set those large areas of nodata values as well as areas where only one raster is present (this is the case when unioning two contiguous non-overlapping rasters) as a block (not pixel by pixel or in a "memset manner") is still in development. See http://trac.osgeo.org/postgis/browser/trunk/raster/scripts/plpgsql/st_mapalgebra_optimized.sql The idea is to set blocks of the resulting raster using ST_SetValues() (described in [http://trac.osgeo.org/postgis/wiki/WKTRaster/SpecificationWorking02 Objective 2.0.05]) instead of processing one pixel at a time. This is somewhat similar to setting a large block of memory with memcpy() or memset() rather than setting a buffer one value at a time. The resulting raster is divided into rectangular block with the _MapAlgebraParts() function.
    98
    99 ----
    100 == '''Objective FV.26 - ST_Difference() and ST_SymDifference() based on ST_MapAlgebra(raster, raster)''' ==
    101
    102
    103  -ST_Difference(raster1, band1, raster2, band2)
    104
    105  -ST_SymDifference(raster1, band1, raster2, band2)
    106
    107  See at the end of [http://trac.osgeo.org/postgis/browser/trunk/raster/scripts/plpgsql/st_mapalgebra.sql plpgsql/st_mapalgebra.sql][[BR]]
    108
    109 ----
    110 == '''Objective FV.27 - Integrate different custom functions, to be used with ST_MapAlgebraFct(), to extract values from a coverage''' ==
    111
    112  * These are quick to implement ST_MapAlgebraFct() custom functions setting raster pixel values from any king of existing coverage. They all accept the name of the schema, the name of table and the name of raster (or geometry) column from which to extract values. They can also accept additional parameters.
    113
    114  * One way to organize/classify/make sense all those possible functions goes like this:
    115
    116   1) Functions searching for the pixel value in a raster coverage. This is the same principle as ST_Union() except that the rasters do not have to be aligned (nice advantage!).
    117
    118   2) Functions searching for the pixel value in a vector coverage. This is the same principle as ST_UnionToRaster() and ST_BurnToRaster().
    119
    120   3) Functions aggregating pixel values from a raster neighborhood. This is the same principle as ST_MapAlgebraFctNbg() except that the target raster do not have to be aligned with the source raster (nice advantage!).
    121
    122   4) Functions aggregating pixel values from a vector neighborhood. This is the only way to do that.
    123
    124   5) Functions deriving metric values from a raster or a geometry coverage. This is very similar to the two previous items but the result is not an aggregate value. e.g. Distance to something.
    125
    126  Category 1), not working on pixel neighbour area, hence only on aligned pixels from overlapping rasters, should eventually be replaced by the optimized version of ST_Union() (itself dependent on the optimized version of ST_MapAlgebra See Objective FV.25 above). Those alternative are less flexible than their future ST_Union alternative in that they only work on a whole table, not on a selection of a table (i.e. they are not aggregates like ST_Union is. One can always create a view on a table to work on a table subset though).
    127
    128  * Some examples of such custom functions exists:
    129
    130   * ST_FasterUnion('schemaname', 'tablename', 'rastercolumnname'), a temporary alternative to ST_Union(rast, 'LAST') - Merge all the tiles of a table together into a single raster. This function act as a wrapper around the ST_FirstRasterValue4ma() ST_MapAlgebraFct() custom function and is described [http://geospatialelucubrations.blogspot.fr/2012/07/a-slow-yet-1000x-faster-alternative-to.html here].
    131
    132   * ST_FirstGeomValue4ma() - Get the value from a specified column from the first geometry intersecting with the shape of the pixel (See [http://postgis.refractions.net/pipermail/postgis-users/2012-April/033875.html this post to postgis-users])
    133
    134  * Other possible functions:
    135
    136   * ST_GeomToRaster('schemaname', 'tablename', 'geomolumnname', 'METHOD') (Category 2) - A generalization of ST_FirstGeomValue4ma() described above but accepting more methods of value extraction, depending on the type of coverage we want to extract from. This is very much like doing an intersection (actually more like an "identify" overlay operation) between a raster and a vector coverage.
    137
    138   This function can further be generalised by adding parameters to define a buffer area around the pixel centroid or the pixel boundary. This would provide a category 4 type of function. (e.g. ST_Density())
    139
    140  The METHOD could be:
    141
    142   * from any kind of coverage: COUNT, DISTINCT_COUNT, COUNT_MOST_FREQUENT, COUNT_LEAST_FREQUENT, MOST_FREQUENT_VALUE, LEAST_FREQUENT_VALUE, MAXIMUM, MINIMUM, RANGE, SUM, MEAN, STDDEV
    143
    144   * from a line coverage could also be MAX_LENGTH, MIN_LENGTH, LENGTH_RANGE, LENGTH_SUM, LENGTH_MEAN, LENGTH_STDDEV, COMBINED_MAX_LENGTH, COMBINED_MIN_LENGTH, COMBINED_MEAN_LENGTH, COMBINED_STDDEV_LENGTH, LENGTH_OF_LINE_WITH_GREATEST_VALUE, LENGTH_OF_LINE_WITH_SMALLEST_VALUE, LENGTH_OF_LINE_WITH_MOST_FREQUENT_VALUE, LENGTH_OF_LEAST_FREQUENT_VALUE, VALUE_OF_LONGEST, VALUE_OF_SHORTEST, VALUE_OF_COMBINED_LONGEST, VALUE_OF_COMBINED_SHORTEST, WEIGHTED_SUM, WEIGHTED_MEAN
    145
    146   * from a polygon coverage could also be MAX_AREA, MIN_AREA, AREA_RANGE, AREA_SUM, AREA_MEAN, AREA_STDDEV, COMBINED_MAX_AREA, COMBINED_MIN_AREA, COMBINED_MEAN_AREA, COMBINED_STDDEV_AREA, AREA_OF_POLYGON_WITH_GREATEST_VALUE, AREA_OF_POLYGON_WITH_SMALLEST_VALUE, AREA_OF_POLYGON_WITH_MOST_FREQUENT_VALUE, AREA_OF_LEAST_FREQUENT_VALUE, VALUE_OF_LARGEST, VALUE_OF_SMALLEST, VALUE_OF_COMBINED_LARGEST, VALUE_OF_COMBINED_SMALLEST, WEIGHTED_SUM, WEIGHTED_MEAN
    147
    148   * ST_EuclidianDistance() (see [http://trac.osgeo.org/postgis/wiki/PostGIS_Raster_SoC_Idea_2012/Distance_Analysis_Tools the GSoC project]) this function takes advantage of the KNN index of geometry to quickly find the geometry nearest to the pixel centroid and compute its distance.
    149
    150 ----
    151 == '''Objective FV.28 - Add some function interpolating a raster from a geometry layer''' ==
    152
    153  * ST_Interpolate('schemaname', 'tablename', 'geomolumnname', 'METHOD') - Method could be 'NEAREST_NEIGHBOR', 'IDW', 'KRIGING', 'NATURAL_NEIGHBOR', 'SPLINE', 'REG_SPLINE_WITH_TENSION', etc...
    154
    155 ----
     79
    15680== '''Objective FV.04 - Have ST_Union() variants accepting a set of temporary expressions''' ==
    15781
    514438
    515439----
     440== '''Objective FV.24 - ST_MapAlgebraFctNbg() working on a tiled coverage''' ==
     441
     442
     443'''ST_MapAlgebraFctNgb('''rasttable text, rastcolumn text, band int, pixeltype text, radius int, funcname text[, funcargs text]''') -'''
     444
     445 A one raster version taking a '''table name and a raster column name''' (in order to work on a '''tiled coverage''') and a '''user defined function''' (with optional parameters) of the set of first, second, etc... '''neighbours''' of a pixel. This version work transparently on a tiled coverage avoiding edges effects.
     446
     447 The function could 1) search itself for out of bound pixel values or 2) pass the name of the table to search for those values and let this job to the custom function. (I think 1) is a better option since the actual predefined custom functions would work tranparently).
     448
     449 Open question: What to do when there are more than one pixel (because they are overlapping) value neighbouring the current pixel? Could be another parameter saying take the 'MIN', the 'MAX', the 'FIRST', the 'LAST', the 'MEAN'...
     450
     451 See also: [wiki:WKTRaster/MapAlgebra Notes taken by David Zwarg during the Montreal Code Sprint 2011] and ticket #860.
     452
     453----
     454== '''Objective FV.25 - Optimized version of two rasters ST_MapAlgebra()''' ==
     455
     456 * ST_MapAlgebra(raster, raster, 'UNION') can be optimized by not iterating on every pixels when it is not necessary. "Chunk" (or large areas) of pixels, outside the intersecting area of the two raster can be set in a "memset manner".
     457
     458 * The prototype of an optimized version, trying to set those large areas of nodata values as well as areas where only one raster is present (this is the case when unioning two contiguous non-overlapping rasters) as a block (not pixel by pixel or in a "memset manner") is still in development. See http://trac.osgeo.org/postgis/browser/trunk/raster/scripts/plpgsql/st_mapalgebra_optimized.sql The idea is to set blocks of the resulting raster using ST_SetValues() (described in [http://trac.osgeo.org/postgis/wiki/WKTRaster/SpecificationWorking02 Objective 2.0.05]) instead of processing one pixel at a time. This is somewhat similar to setting a large block of memory with memcpy() or memset() rather than setting a buffer one value at a time. The resulting raster is divided into rectangular block with the _MapAlgebraParts() function.
     459
     460----
     461== '''Objective FV.26 - ST_Difference() and ST_SymDifference() based on ST_MapAlgebra(raster, raster)''' ==
     462
     463
     464 -ST_Difference(raster1, band1, raster2, band2)
     465
     466 -ST_SymDifference(raster1, band1, raster2, band2)
     467
     468 See at the end of [http://trac.osgeo.org/postgis/browser/trunk/raster/scripts/plpgsql/st_mapalgebra.sql plpgsql/st_mapalgebra.sql][[BR]]
     469
     470----
     471== '''Objective FV.27 - Integrate different custom functions, to be used with ST_MapAlgebraFct(), to extract values from a coverage''' ==
     472
     473 * These are quick to implement ST_MapAlgebraFct() custom functions setting raster pixel values from any king of existing coverage. They all accept the name of the schema, the name of table and the name of raster (or geometry) column from which to extract values. They can also accept additional parameters.
     474
     475 * One way to organize/classify/make sense all those possible functions goes like this:
     476
     477  1) Functions searching for the pixel value in a raster coverage. This is the same principle as ST_Union() except that the rasters do not have to be aligned (nice advantage!).
     478
     479  2) Functions searching for the pixel value in a vector coverage. This is the same principle as ST_UnionToRaster() and ST_BurnToRaster().
     480
     481  3) Functions aggregating pixel values from a raster neighborhood. This is the same principle as ST_MapAlgebraFctNbg() except that the target raster do not have to be aligned with the source raster (nice advantage!).
     482
     483  4) Functions aggregating pixel values from a vector neighborhood. This is the only way to do that.
     484
     485  5) Functions deriving metric values from a raster or a geometry coverage. This is very similar to the two previous items but the result is not an aggregate value. e.g. Distance to something.
     486
     487 Category 1), not working on pixel neighbour area, hence only on aligned pixels from overlapping rasters, should eventually be replaced by the optimized version of ST_Union() (itself dependent on the optimized version of ST_MapAlgebra See Objective FV.25 above). Those alternative are less flexible than their future ST_Union alternative in that they only work on a whole table, not on a selection of a table (i.e. they are not aggregates like ST_Union is. One can always create a view on a table to work on a table subset though).
     488
     489 * Some examples of such custom functions exists:
     490
     491  * ST_FasterUnion('schemaname', 'tablename', 'rastercolumnname'), a temporary alternative to ST_Union(rast, 'LAST') - Merge all the tiles of a table together into a single raster. This function act as a wrapper around the ST_FirstRasterValue4ma() ST_MapAlgebraFct() custom function and is described [http://geospatialelucubrations.blogspot.fr/2012/07/a-slow-yet-1000x-faster-alternative-to.html here].
     492
     493  * ST_FirstGeomValue4ma() - Get the value from a specified column from the first geometry intersecting with the shape of the pixel (See [http://postgis.refractions.net/pipermail/postgis-users/2012-April/033875.html this post to postgis-users])
     494
     495 * Other possible functions:
     496
     497  * ST_GeomToRaster('schemaname', 'tablename', 'geomolumnname', 'METHOD') (Category 2) - A generalization of ST_FirstGeomValue4ma() described above but accepting more methods of value extraction, depending on the type of coverage we want to extract from. This is very much like doing an intersection (actually more like an "identify" overlay operation) between a raster and a vector coverage.
     498
     499  This function can further be generalised by adding parameters to define a buffer area around the pixel centroid or the pixel boundary. This would provide a category 4 type of function. (e.g. ST_Density())
     500
     501 The METHOD could be:
     502
     503  * from any kind of coverage: COUNT, DISTINCT_COUNT, COUNT_MOST_FREQUENT, COUNT_LEAST_FREQUENT, MOST_FREQUENT_VALUE, LEAST_FREQUENT_VALUE, MAXIMUM, MINIMUM, RANGE, SUM, MEAN, STDDEV
     504
     505  * from a line coverage could also be MAX_LENGTH, MIN_LENGTH, LENGTH_RANGE, LENGTH_SUM, LENGTH_MEAN, LENGTH_STDDEV, COMBINED_MAX_LENGTH, COMBINED_MIN_LENGTH, COMBINED_MEAN_LENGTH, COMBINED_STDDEV_LENGTH, LENGTH_OF_LINE_WITH_GREATEST_VALUE, LENGTH_OF_LINE_WITH_SMALLEST_VALUE, LENGTH_OF_LINE_WITH_MOST_FREQUENT_VALUE, LENGTH_OF_LEAST_FREQUENT_VALUE, VALUE_OF_LONGEST, VALUE_OF_SHORTEST, VALUE_OF_COMBINED_LONGEST, VALUE_OF_COMBINED_SHORTEST, WEIGHTED_SUM, WEIGHTED_MEAN
     506
     507  * from a polygon coverage could also be MAX_AREA, MIN_AREA, AREA_RANGE, AREA_SUM, AREA_MEAN, AREA_STDDEV, COMBINED_MAX_AREA, COMBINED_MIN_AREA, COMBINED_MEAN_AREA, COMBINED_STDDEV_AREA, AREA_OF_POLYGON_WITH_GREATEST_VALUE, AREA_OF_POLYGON_WITH_SMALLEST_VALUE, AREA_OF_POLYGON_WITH_MOST_FREQUENT_VALUE, AREA_OF_LEAST_FREQUENT_VALUE, VALUE_OF_LARGEST, VALUE_OF_SMALLEST, VALUE_OF_COMBINED_LARGEST, VALUE_OF_COMBINED_SMALLEST, WEIGHTED_SUM, WEIGHTED_MEAN
     508
     509  * ST_EuclidianDistance() (see [http://trac.osgeo.org/postgis/wiki/PostGIS_Raster_SoC_Idea_2012/Distance_Analysis_Tools the GSoC project]) this function takes advantage of the KNN index of geometry to quickly find the geometry nearest to the pixel centroid and compute its distance.
     510
     511----
     512== '''Objective FV.28 - Add some function interpolating a raster from a geometry layer''' ==
     513
     514 * ST_Interpolate('schemaname', 'tablename', 'geomolumnname', 'METHOD') - Method could be 'NEAREST_NEIGHBOR', 'IDW', 'KRIGING', 'NATURAL_NEIGHBOR', 'SPLINE', 'REG_SPLINE_WITH_TENSION', etc...
     515
     516----
    516517== '''Other functions''' ==
    517518
